Teegul and Tec?
8 replies to this topic
#1 Emanuele
Emanuele
    Lord of the Ring
Posted 11 June 2009 - 10:51 AM
Guys and Girls,
I really miss my Teegul Lapides mount. I might pick on up in the future, but I'm wondering if it can support my TEC140 or I will be pushing the limits a bit too far?
The mount will sit on my Gitzo GT5531CF tripod - 55 lbs payload.
Emanuele
#2 highwood
highwood
Posted 11 June 2009 - 02:41 PM
Emanuele:
I have a TEC 140, a Lapides-mod Teegul, and the same Gitzo you do; however, I have not tried to use them together and don't think I ever will. The mount and tripod are excellent for my 4" f6 refractor, but the TEC weighs twice as much and is nearly double the length. I wouldn't be willing to push the limits that far, but I'm pretty risk-averse in general.
#3 Emanuele
Emanuele
    Lord of the Ring
Posted 11 June 2009 - 02:48 PM
Jim,
thank you for your thoughts: the 140 is pretty long and yes, I agree, it would actually be kind of a risk to try this setup out.
I am finding to be hard to find an Alt/Az mount with slowmo controls that is comparable to the Teegul Lapides.....
E.
#4 highwood
highwood
Posted 11 June 2009 - 03:25 PM
If a beefed up version of the Teegul existed, I'd jump on it myself! I've used a Universal Astronomics alt-az, mounted on an AP wooden tripod, with the TEC. It's OK, but I have some balance issues. So I've been tending just to drag out GEM: the extra stability and the drive have made the extra effort worthwile.
Good luck finding what works for you.
#5 Emanuele
Emanuele
    Lord of the Ring
Posted 11 June 2009 - 03:38 PM
Yep, I'd jump on it as well.
I would use this, as I did before, to image from my apartment balcony or through my window.
I miss that a lot.
E.
#6 Scott99
Scott99
Posted 11 June 2009 - 05:58 PM
Guys and Girls,
Emanuele
TEC140 on a Teegul is not going to fly! Way too big and heavy.
There is an article on Amart from a guy who heavily modified his Teegul to carry a TEC140, but by the time he got done with it you can barely recognize the mount anymore!
#7 Herenomore
Herenomore
Posted 11 June 2009 - 06:15 PM
Jim,
E.
Seems like a small price to pay for a decent set of slo-mo's. Give the teegul a shot and let us know how that works out for you.
#8 CESDewar
CESDewar
    GorillAstronomer
Posted 12 June 2009 - 12:22 AM
I have a Teegul mount on a Gitzo 5530s tripod and have put my SCT-8 on it which, fully loaded can top 21 lbs. I've also put my NP-127 fully loaded on it too - which was about the same. BTW - you had a comment about a 55lb payload? My understanding is that the TEC-140 is around 20lbs for the OTA and should therefore be around 30lbs with finder/rings/diagonal/EP ??
Both my C-8 and Np-127 worked just fine - settling time with the NP-127 was about 2 seconds with vibration pads which I consider more than reasonable.
But a TEC-140 is many pounds heavier again. My guess is that the Teegul mount could in fact carry it, but would become unworkable in a light wind etc. I observe from the bottom of a valley where there is never any wind while observing.
I agree that there are definitely few choices in a more robust AltAz with SloMo controls. I just really prefer SloMo controls and so using the NP-127 on the Teegul is something I prefer over using it on my DM-6, even though the DM-6 is a more stable mount.
#9 NHRob
NHRob
Posted 12 June 2009 - 10:59 AM
The Stellarvue MG/MGE mount has slo-mo controls. It looks a bit beefier than a Teegul but I am not sure. Worth looking into.
Rob
