CG5-did I make a boo boo by updating the firmware
5 replies to this topic
#1 seeker372011
seeker372011
Posted 13 June 2009 - 03:54 AM
I updated the HC and MC firmware on my CG5-which has given me sterling service over the years
I was sucked in by the new polar alignment routine which I thought would be really nifty
anyway though I did the update some time ago, thanks to weather and competition with another mount-never really had a chance to try it out till last night..when I only got a short while before cloud
However I found that it was way way way off on both first and second alignment stars. This never used to be the case with the original firmware
anyway I dragged it back using the HC added a couple of calibration stars and it found a bright test object OK
I then tried to use the polar alignment routine -on the star I was on , which happened to be Hadar-and the OTA wound up pointing at the ground!
I did a factory reset, entered location date time etc etc all over again and the same problem with alignment stars; I could not complete alignment because of 100% cloud...but is there some known southern hemisphere bug with the latest upgrade?
did anyone else have a similar problem?
is there an undo button somewhere :(
Is it worth trying Celestron tech suport help? the last time I wrote them -on another issue-it took a week to get an acknowledgement, and I got much better advice here on CN well before which resolved my issue
thanks for any hints
Narayan
#2 rmollise
Posted 13 June 2009 - 08:27 AM
Which build did you update to? There _was_ a Southern Hemisphere bug with 4.15...
#3 seeker372011
seeker372011
Posted 14 June 2009 - 04:44 AM
Rod
indeed it was v 4.15 !!!
you say "was"-so presumably its now fixed-so if I just update it should work hopefully???
Narayan
#4 seeker372011
seeker372011
Posted 14 June 2009 - 05:02 AM
just downloaded 4.16
for some reason I had to uninstall the earlier version of HC update-it simply would not connect and download and install a new version..and it straight away told me that there was a new version with a southern hemisphere fix--so hopefully that solves the issue
thanks Rod for your assistance once again..I hope to be using the new polar alignment routine soon, if all goes well
Clear skies
Narayan
#5 rmollise
Posted 14 June 2009 - 04:47 PM
Clear skies
Narayan
Let us know how it goes, but I'm a-guessin' you will be fine now. :jump:
#6 seeker372011
seeker372011
Posted 23 June 2009 - 07:20 AM
Clear skies
Narayan
First clear night-worked like a charm !!!
the any star polar alignment was brilliant-fastest I have ever been polar aligned !!
This is a fantastic feature...thanks Rod
Narayan :cool: :cool: :cool: :)
