Smallest Possible Alt/Az Mount for small refractor
11 replies to this topic
#1 Domerman
Domerman
    Just Lucky, I Guess.
Posted 16 June 2009 - 10:17 PM
I have an AT66ED and I am looking for a small, cheap, and effective non-powered mount for the little scope. It must be travel friendly and around 100 bucks. Camera mounts are possible if they can handle the scope. Buying used is definitely an option and likely the most viable option for me. Any recommendations?
#2 JadeSmith
JadeSmith
Posted 16 June 2009 - 10:30 PM
I've seen used Stellarvue M1's for $100ish...
There seems to be a steady supply of used camera tripods on Craig's List. Most appear to have terrible resale value too, so lots of cheap options...
#3 Domerman
Domerman
Posted 18 June 2009 - 04:07 PM
Not too many opinions on this I see.
#4 Ron B
Ron B
Posted 18 June 2009 - 07:50 PM
The Stellarvue M1 is very compact and would be great on a photo tripod.
Universal Astronomics has the MicroStar or UniStar Light which is 2 lbs. I haven't had any experience with this mount; but I've seen them come up used on Astro Mart as well.
Ron
#5 Jeff in Austin
Jeff in Austin
Posted 18 June 2009 - 08:21 PM
How would the Stellarvue M1 compare with a Bogen fluid head?
#6 muni
muni
Posted 18 June 2009 - 08:42 PM
I have the M1 mount. Works great but I find it heavy and bulky for something you want to backpack with.
How about Borg's single arm mount?
http://www.sciencece...s/html/3101.htm
Twice your budget, though. And I'm not certain of the carrying load.
#7 TONGKW
TONGKW
Posted 19 June 2009 - 12:10 AM
I purchased a Maxvision K2 AltAz mount for my nephew for mounting a 80 mm refractor. It appears to be a clone of the Mizar K mount and works well and the cost in Hong Kong is about US$96.
http://www.hkastroeq...om/fj03-02.html
K W TONG
C8 + CG-5GT, TSA102 + HEQ5 PRO, MK67 + Voyager Mount, WO ZS 80FD + Kenko NES, NexStar 6SE, WO Megrez 72 + Mizar K Mount, Mini Borg 50, C5, PST
#8 Jim7728
Jim7728
Posted 19 June 2009 - 09:45 AM
I've successfully used a Orion EQ-1 tabletop mini in a alt/az configuration with a TV-70mm Ranger. Did the same with an old Meade EQ-2 type mouint. New mini goes for $59. Used EQ-1 or 2 with 1/4" adapter should be obtainable for $100 or less.
Old EQ-2 type Meade equatorial in a alt/az configuration.
#9 yagobet
yagobet
Posted 19 June 2009 - 04:03 PM
Bogen 3001 tripod with 3130 head works great with my st80 (up to 100x). Weights only 7 lb.
#10 spmv
spmv
Posted 20 June 2009 - 11:58 AM
Universal Astronomics makes a great one. I believe its called the Dwarfstar.
#11 Nick-Sydney
Nick-Sydney
Posted 23 June 2009 - 12:29 PM
There is a little brother to the Giro III (forget the name) which looks good. I have a Giro II and very happy so far, so I suspect he smaller Giro would also be very good.
#12 Jim7728
Jim7728
Posted 23 June 2009 - 02:43 PM
Giro-Mini. Costs alot more than the OP's budget of $100, but is great little mount. Recommend matching with tripod that has adjustable column. ;)
