Beginner Mount Questions
5 replies to this topic
#1 bonorden
bonorden
Posted 22 June 2009 - 12:10 AM
I recently purchased a used CG5. It seems to work reasonably well but I tried doing some piggyback photography and the mount seemed to strain when slewing. And the accuracy of the gotos was off some. I rebalanced after putting on the camera but I've come to the conclusion that the mount could benefit from a hypertune. The RA turns fairly easily, but the DEC is a little harder to move. My question is about the weight limit of the CG5. I'm running a C8 with an 11 lb counterweight. I have a 8x50 finderscope, a telrad and my DSLR (4 lbs). I've been told that the CG5's limit is ~30lbs and I should strive to keep the weight to ~15 lbs. I don't see how this can be done unless you don't count the counterweights in the equation.
1) Do you count the counterweights?(I'm assuming you would since weights weigh something). If I remove my DSLR and replace with a CCD for imaging and another for guiding (after replacing my finder for a guidescope), I'll likely be well over 30 lbs.
2) Is it possible to be under the 30 lbs with a C8 with an astrophotography rig I am describing?(I'm assuming yes, but the math doesn't seem to add up).
Jeff
#2 neptun2
neptun2
Posted 22 June 2009 - 02:50 AM
First the counterweights does not count. The limit is given for the useful load. Giving rating of 30 lbs for cg5 does not sound right to me. It has the same mechanics as EQ5 so it should be rated rather for 20lbs i think. But you should have no problems with c8 and your imaging gear with this mount. Of course at this focal length with this mount and without reducer you will probably need autoguiding for long exposure astrophotography.
#3 Luigi
Luigi
Posted 22 June 2009 - 05:54 AM
How old is the CG5? Celestron upgraded the CG5 a few years ago when they started selling it with a C11, which weighs about 30lb. IMO, that's pushing the envelope a bit but at least the C11 is short, which helps. If properly balanced, the weight is no problem for the mount, it's just wobbly when observing. I had a C11 on a G11 for many years and that was a great setup, but when I downsized OTAs I downsized from the G11 to the CG5, which I find works very well with my current ~16 lb OTAs. The CG5 is noisy when slewing at full speed. Don't take the noise as being indicative of a problem.
As for tuning the mount, the only thing that gets done is regreasing and minimizing play and backlash. This usually isn't necessary or beneficial.
#4 bonorden
bonorden
Posted 22 June 2009 - 07:43 AM
Supposedly the mount is only a couple of years old. It looks like the "new" mount style and has an upgradeable hand controller running version 4.12.
#5 LLEEGE
LLEEGE
    True Blue
Posted 22 June 2009 - 10:15 AM
I assume you're piggybacking your camera as you don't mention another scope. You should be fine with that setup. You may want to check the worm mesh to make sure it's not too tight.
#6 Rcade
Rcade
Posted 23 June 2009 - 11:10 AM
I think 30 lbs for any CG5 is a bit too much. I have an older one and have run it with 24 lbs OK but I would not go higher as it was at its limit there. Hypertuning will help even out the mounts mechanical deviation and ply but will not help with weight at all. I routinely run my CG5 with an olderr, heavier, Celestron C8 and have not had any problems with it handling the weight. Good Luck !!!
