Polaris clutch fitting
2 replies to this topic
#1 daniel_h
daniel_h
Posted 22 June 2009 - 05:35 AM
have purchased a vixen polaris & clutch but am unsure how to fit the two together,any suggestions welcome
thankyou
#2 rjsc2000
rjsc2000
Posted 22 June 2009 - 04:38 PM
The bronze or yellowish part goes to the worm on the mount. It has has a small (2,5mm) screw that has to be tighten. The the motor goes on the other end. The silver part has a screw that has to be tighten so that when the motor turns it also turns the worm. Hope it helps
ricardo
#3 Littlegreenman
Littlegreenman
Posted 27 June 2009 - 11:57 PM
Daniel,
Did you buy the clutches from me?
Here is a link to some manuals for the Great Polaris and Super Polaris mounts on the Company 7 Website. The Polaris is a little different, but once you get the general idea it's easy to figure out.
BTW, If you did get the clutches from me, I think I included a little Allen wrench for tightening the brass clutch piece on to the worm gear shaft.
The first two are large PDFs.
clutch installation instructions
Polaris MT-1 motor install sheet
Index of related pages
Good luck, LGM
