Powered USB or not?
3 replies to this topic
#1 lernerda
lernerda
Posted 29 June 2009 - 10:16 AM
My eletronic setup includes a laptop w/3 USB 2.0 ports, a Tak EM200(temma PC goto), 2 DSIs, rs232 and autoguider cables. Everything is run by the USB's. Now I KNOW you need the direct USB 2.0 ports for the DSIs (pluged directly into the computer), but here is my question.
I have a 4-port, non-powered USB 1.1 hub... Will this work OK for the Goto and autoguider simutaneously plugged into the third port (maybe a mouse also)? As I said, I know the DSIs need direct 2.0 connections (or a powered USB 2.0 hub), but am I OK with the goto and autoguider ussing a non-powered hub? (it's not like it is sending 5 Mb/sec).
Opinions?
#2 Mike Clemens
Mike Clemens
    Frozen to Eyepiece
Posted 29 June 2009 - 04:54 PM
Didn't work here. I tried a non-powered micro-hub on the scope itself (so I could run a single USB line out to it) but it failed to work and I switched back to a powered hub at the mount. I was using a DSI Pro and an EOS camera at the scope.
#3 David Pavlich
David Pavlich
    Transmographied
Posted 30 June 2009 - 09:55 AM
Same as Mike. Get a good powered hub and you won't have that part of your electronics to worry about.
David
#4 scope dog
scope dog
Posted 30 June 2009 - 09:10 PM
I have a astronomy camera dbk 41 and have a 25 ft run. web page This will work at 3.5 fps and sometimes 7.5, but faster in BW mode. But I tried power hubs on a run but had develope driver issues and also repeaters. The reason this does not work at 15fps is the data flow is bi directional, maybe a ccd camera might be better.
