setting circle alignment
3 replies to this topic
#1 flatleyld
flatleyld
Posted 10 July 2009 - 12:24 AM
I'm working on applying some setting circles on the mount of my lightbridge. I
was just wondering what is the best way to align the azimuth axis? Some things
I've read about are aligning to north with a compass, or to align to Polaris.
Which is the correct way to align the azimuth setting circle?
#2 rmollise
Posted 10 July 2009 - 06:51 AM
You'll want to use Polaris. Point scope at Polaris, and set your aziumuth circle to 0.
#3 flatleyld
flatleyld
Posted 10 July 2009 - 11:37 AM
Got it! Thank you very much for your help on that.
#4 CT1001
CT1001
Posted 10 July 2009 - 01:25 PM
I use Polaris as well, although I've heard of people trying to use compasses with varying degrees of success. Using Polaris is a piece of cake.
Also, make sure that you have the scope's base level. If it's not level (or close to it), then every thing will be slightly (or not so slightly) off when you're trying to locate objects.
Good luck - setting circles was one of the best things I did for astronomy.
