Mizar K, Maxvision K & TS alt/az mount.
5 replies to this topic
#1 Darren B
Darren B
Posted 11 July 2009 - 12:10 PM
Has anyone have any experience of these mounts. Last Christmas I bought a Bresser 70mm Scope which came with an alt/az mount which looks the same as the Mizar, Maxvision and TS mounts. The mount itself handles my SW66ED scope with ease, however it has the worse tripod I have seen on any telescope. I would only recomend using this tripod for a compact digital camera. Luckily the standard tripod can be taken off and a standard astro tripod can be added. With a decent tripod added, what size scope and magnification can this mount handle? TS AZ mount
#2 Jim7728
Jim7728
Posted 11 July 2009 - 02:18 PM
I'd go with TS description of 2 KG limit. A good tripod should help steady vibes at higher mags, but would not put anything larger than the 70mm scope that came with it.
BTW, I was looking at what appears to be the same mount head from this vendor for my TV-60. If it can handle your 66mm, then should handle my 60. :cool:
#3 Darren B
Darren B
Posted 11 July 2009 - 03:28 PM
Hi Jim, I once owned that mount that you are looking at. It's very similar, but a little different. It worked fine with a ST80 & 90mm Mak. It'll do the job with the TV60.
#4 TONGKW
TONGKW
Posted 11 July 2009 - 09:22 PM
I have both. Both can easily support my C5 and a 80 mm short refractor OTA.
The Mizar K AltAz mount is from Japan. The Maxvision K AltAz mount is from China. Both are currently available here in Hong Kong with the Maxvision K AltAz mount listing at RMB650 (approximately US$96) and the Mizar K AltAz mount at HK$1200 (approximately US$155).
http://www.grandeye....k/7yearsale.htm
http://www.hkastroeq...om/fj03-02.html
K W TONG
C8+CG-5GT, TSA102+HEQ5 PRO, MK67+Voyager Mount, NexStar 6SE, C5 + Mizar K Mount, WO ZS 80FD+Kenko NES, Megrez 72+Kenko KDS, Mini Borg 50, PST
#5 TONGKW
TONGKW
Posted 11 July 2009 - 09:25 PM
William Optics 80FD OTA on Mizar K AltAz mount and Velbon 640 CF tripod.
#6 Darren B
Darren B
Posted 12 July 2009 - 01:11 AM
Interesting that it can handle a C5 & WO80FD, though I'll stick with the 66ED.
