Wierdball issue with ASGT mount - Where's Jupiter?
8 replies to this topic
#1 Preston Smith
Preston Smith
    The Travel Scope Guy
Posted 19 July 2009 - 01:54 PM
A couple of nights ago I had a wierdball situation occur. I had good alignment and had been using the mount for about 2 hours. Earlier in the evening I had pointed the scope towards Jupiter. I decided I wanted to go back to Jupiter to watch a transit but the hand controller no longer gave me the choice of going to Jupiter. All it showed was Saturn. All of the other objects (DSOs and stars) worked fine. A little later the moon had risen but the hand controller did not identify the moon either. Again, I had no problems slewing to DSOs and starrs. Wierd!
Was this a possible low power issue or something else?
#2 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 19 July 2009 - 01:58 PM
That's a time/date/time zone/location error. It didn't know that Jupiter or the Moon were above the horizon.
#3 GShaffer
GShaffer
Posted 19 July 2009 - 02:56 PM
I had a similar unexplainable issue recently with mine. It would do a near perfect goto on anything I tried including the moon but if I punched up Polaris it would slew to about a 30 degree downward angle about 30 degrees east of Polaris....Never done it before and not since. Weirdness.
#4 GaryML
GaryML
Posted 19 July 2009 - 04:01 PM
If it wasn't the date/time/location, then maybe some Northern Hemisphere/Southern setting got changed by accident? I saw another post here along these lines and that was the culprit.
#5 mclewis1
mclewis1
    Thread Killer
Posted 19 July 2009 - 05:44 PM
And one other possibility to those mentioned by John and Gary ... if the filter limits are set incorrectly you'll get that same behavior. Basically the scope is saying to you "according to me Jupiter and the Moon are not above the horizon or the artificial limit you've set".
You might do a reset factory settings, then carefully go through time, date, location, and time zone settings. It's also a good idea to ensure that you've go plenty of power (don't assume).
#6 Preston Smith
Preston Smith
Posted 19 July 2009 - 06:13 PM
Thanks folks for the responses!
I don't think the filters are the issue as I had slewed to Jupiter earlier in the evening when it was lower on the horizon and it went right to it.
If it was a date/time/location issue then why was everything else such as Messiers and double stars coming up almost dead center in my field of view when I would slew to them?
#7 jrcrilly
jrcrilly
Posted 19 July 2009 - 06:18 PM
That's the clue. After alignment, the controller doesn't rely on those data to locate celestial objects, only for Solar system objects.
#8 Preston Smith
Preston Smith
Posted 19 July 2009 - 06:25 PM
Now I'm tracking! Thanks John! I'll go back through my settings, if I don't see it I'll take Mark's advice and go back to the factory settings and start over!
Thanks everyone! Yet another quick solution from the CN collective mind :bow:
#9 rmollise
Posted 20 July 2009 - 07:03 AM
Amen. When you have problems like these, always check your HC data entry.
