Tak 102 clamshell questions: Measurement
2 replies to this topic
#1 titan7
titan7
Posted 24 July 2009 - 02:35 AM
Can someone tell me the measurement of the round base of the Tube holder and the spacing of the hole on center.
thanks! I am assuming these are 1/4" holes?
#2 BarrySimon615
BarrySimon615
    Pa Bear
Posted 24 July 2009 - 08:16 AM
The clamshell base is approx. 3.5" in diameter, perhaps a bit more (90 mm). The holes have a 35 mm spacing.
They are not 1/4", the appropriate bolts are metric, M8, I believe which is close to 5/16, but the M8 bolt will start to thread into 5/16-18, 5/16-24, and 5/16-32 threaded holes, it will quickly bind up. You have to go metric. The supplied metric bolts have a threaded shaft length of approx. 20 mm.
Barry Simon
#3 titan7
titan7
Posted 26 July 2009 - 04:19 PM
thank you!
