APM SuperED-Apo ( FPL 53) 107/700mm - f/6,5
1 reply to this topic
#1 APM M.Ludes
APM M.Ludes
    Vendor (APM Telescopes, Lunt Solar Systems, Lunt Engineering)
  • Restricted Vendors
Posted 31 July 2009 - 07:22 AM
Our new Super ED shows in the serial production a far better quality than I ever would believe to get .
APM Apo 107/700mm - f/6,5 - with 3" crayford-style focuser
High-end colour-corrected 3-lens apochromatic refractor for observing ( and optinal astrophotography - fitted for big CCD cameras).
Airspaced 3-lens system, with FPL 53 glas, certainly fully multicoated. The optical quality is nearly as good as the legendary LZOS optic.
Tube ring info : bottom and top is flat with 5 threads each , also 5 threads are 1/4-20 inch, the 2 outer are 62 mm Losmandy spaced, the 2 inner are 60.2 mm , Astrophysics spaced.
The Optics are guaranted to be better then diffraction limited. Each Lens is startested by APM
Technical data:
- Airspaced 3-lens Apo, fully multycouted
- FPL 53 glas
- aperture: 107mm
- focal length: 700mm
- f/6.5
- tube weight without tube rings: 5.25kg
- tube weight with Rings : 5,95 kg
- Shipping weight : tube with rings and case : 10,40 kg
- weight tube rings: 0.70kg
- tube diameter: 114mm
- dew-shield diameter: 143mm
- diameter front baffle of dew shield : 145 mm
- observing length: 670 mm
- transport length: 570 mm
- backfocus: 180mm
- focuser travel : 115 mm
Delivered by order:
- alu-tube
- movable dew-shield
- CNC made tube rings
- 3" crayford-style focuser with 11:1 reduction
- alu-case
Optional to order :
- - 2,5" flattner
- Camera adapter for field flattner ( we don't know buyers camera )
- finder with bracket and base
cost with 3" Focuser US $ 2,590
Delivery time for the 3" Version : 1 week only
cost with new 2.5" Starlight Instruments Focuser Euro 2,450.00
Start of delivery of the 2.5" version will be around end of august 2009 due a delay in manufacturing this focuser
APM 107 mm f/700 mm Super ED Apo Lens in cell
Specs.
- front cell diameter 124 mm
- rear push pull flange diameter 136 mm
- cell height : 67 mm
- rear cell OD Thread M114 x 1
- lens in cell weight : 1.40 kg
Retail for the Apo Lens in cell US $ 1,200.00
Image Informations:
Apo 107 in combination with 2.5" Fieldflattner
Date: July 2009 seeing 6-7/10; transp. 7-9/10
Scope: 4" APM tripelapo f/6.5 with TS-focuser
CCD: SXVF H16
Filter: Astronomik IIc in FLI 7-slot filterwheel
L,R,G,B,Ha,O3 2 hours each channel, all 1x1 binned
Software: Maxim DL 4.0 image acquisition, Astroart4 autoguiding,
preprocessing in CCD Stack
Processing: postprocess. PS CS2
Author: Dietmar Hager, Austria
http://www.stargazer....com/M27-4.html
#2 Moggi1964
Moggi1964
    Vendor - Astro Laugh
Posted 31 July 2009 - 02:05 PM
And of course, available through APM America......bringing quality astrographs closer to home!
