mounts
4 replies to this topic
#1 mtnmax
mtnmax
Posted 20 August 2009 - 11:40 PM
I bought a new celestron 8"advanced just last year and have since moved up to the 11" carbon fibre tube bought here. I find the viewing wobbly :jump: very hard to get a clean look. Do I need to go up in size??Is there anything I can do to this mount to work???Thanks Terry
#2 rmollise
Posted 21 August 2009 - 07:50 AM
Do you have a set of Celestron's vibration suppression pads under the legs? That will help a lot. So will a motofocus. I'd try these (cheaper) solutions first. I find the CG5 does a pretty good job (visually) with the 11.
#3 Luigi
Luigi
Posted 21 August 2009 - 12:10 PM
I agree that the C11 should be OK for visual on a CG5. There can be a fair amount of flex in long Vixen style dovetails. It's been a while since I looked at C11SGT so don't no if it has a problem with that. There are stiffer solid dovetails available than might help stiffen things up. An adjustable height observing chair can help by allowing you to keep the tripod less than fully extended.
#4 GShaffer
GShaffer
Posted 21 August 2009 - 02:24 PM
I have used my CG5 with my C11 and it is quite passable for visual with the legs fully extended after installing the feathertouch 2 speed microfocus but considerably better if I dont extend but rather use my chair.....
#5 mtnmax
mtnmax
Posted 21 August 2009 - 04:22 PM
Thanks I will try those first/.....Terry
