2" leg upgrade on a CSE mount...anyone?
6 replies to this topic
#1 bcuddihee
bcuddihee
Posted 21 August 2009 - 07:51 AM
I was hoping to retrofit my C8SE mount with the larger diameter 2" stainless steel legs instead of the 1-1/2" inch ones it comes with. I feel it would add greatly to the stability of this mount. Has anyone done this and which legs from what mount would be interchangeable. I had at one time a Skyview pro mount and from what I remember those loegs would seem to do the trick. Anyway, I'd appreciate hearing from anyone who has upgraded their c8se mount in this way. Thanks bc :question:
#2 pollux
pollux
    artiste
Posted 21 August 2009 - 09:15 AM
can you post a photo of the tripod (espeically the hub)?
need to make sure it is the same (or similar) one I dealt with before
if so I have a solution but it will cost some $$$$
#3 bcuddihee
bcuddihee
Posted 21 August 2009 - 11:13 AM
Pollux, here is the hub.
#4 bcuddihee
bcuddihee
oops
#5 pollux
pollux
    artiste
Posted 21 August 2009 - 11:14 AM
Need a bottom view.
#6 bcuddihee
bcuddihee
Posted 21 August 2009 - 11:20 AM
another
#7 pollux
pollux
    artiste
Posted 21 August 2009 - 11:28 AM
Very easy solution.
All you need is to buy a set of 2" steel leg for either Meades' LXD75 or Antares EQ5 (tripod alone if I am not mistaken it's around $200 new. Used of course is a lot cheaper)
Take the leg out and install it to your C8's hub. The width is 99% the same. Depending on your case you may need *very* little shimming or filing. But in the three transplants I have done require none.
