CG5 Tripod leg
3 replies to this topic
#1 hseokman
hseokman
Posted 21 August 2009 - 06:49 PM
Where can I get CG5 Tripod leg?
I have bent inner tube that it does not extend.
How do you lock not too much when setting up heavy telescope?
Is there any compatible ones?
Is there any better upgrade for a tripod for CG5?
#2 titan7
titan7
Posted 21 August 2009 - 07:47 PM
Tele vue Gibralter Wooden "Ash" tripod will turn your CG5 into a much better platform.
#3 pollux
pollux
    artiste
Posted 21 August 2009 - 11:31 PM
CG5's original Synta-made 2" steel tripod now looks like can only be acquired used.
There's an alternative - 2" steel made by Jinghua. Antares imports this set of leg. Works totally fine with all the ex-CG5/EQ5 mounts I had
#4 hseokman
hseokman
Posted 24 August 2009 - 02:03 PM
I searched for Tele vue Gibralter Wooden "Ash" tripod.
How do I mount CG5 on this tripod? Is there adapter plate available from somewhere?
How is it compared from 'Walnut'?
How is it compared with Antares Pedestals?
I have C10N and I use for visual and little bit of imaging.
I plan to upgrade the mount to CGEM later but not soon. Will these be compatible with the CGEM mount?
