CG-5ASGT CGEM Pier mount
6 replies to this topic
#1 DCS357
DCS357
Posted 02 September 2009 - 11:56 PM
I am having a plate machined for my CG5 to be mounted on a pier in my back yard. Was wondering if a CGEM would fit on the same plate or is there some difference in the way a CGEM attaches to the tripod than a CG5 would? Kind of looking to get a CGEM and would be happy if it would mount the same way as my CG5.
thanks
don c
#2 Charlie Hein
Charlie Hein
Posted 03 September 2009 - 05:46 AM
Since the base of the CGEM is quite a bit larger than the CG-5. This means that the azimuth adjustment bolt will be further out from the center hole than it is with the CG-5.
You *could* design a larger plate with two holes for the AZ bolt to deal with this... :wron:
#3 mclewis1
mclewis1
    Thread Killer
Posted 03 September 2009 - 12:04 PM
Don, If you're poking around for info keep an eye out for specs on the Atlas/EQ-6, the base of the CGEM is the same as the Atlas.
#4 jrbarnett
Posted 03 September 2009 - 06:00 PM
Nope.
I have an Atlas and a CG5-GT, and an adapter that allows me to mount the Atlas into the top of the Orion SVP pier extension. The Atlas base and CGEM base are "pin compatible."
I had hoped that the adapter would allow me to mount the Atlas on mt Antares Pier (which is currently configured for a CG5-GT), but alas no. The three bolt tappings that hold the adapter in the Pier do not match up with the holes drilled into the Pier for the CG5-GT adapter. The Atlas adapter mounts "deeper" down the throat of the Pier. I plan on drilling an extra set of holes equidistant between and below the existing holes to make the Pier "dual use".
#5 DCS357
DCS357
Posted 04 September 2009 - 02:42 PM
Thanks for the info. I guess I will wait till I get the CGEM :-) and have a second plate machined.
agin
thanks
#6 Taylor
Taylor
Posted 04 September 2009 - 03:16 PM
Would the Atlas pier extension Orion sells be compatible with the CGEM and its tripod?
#7 mclewis1
mclewis1
    Thread Killer
Posted 04 September 2009 - 04:35 PM
From what I've heard from CGEM owners ... yes it is.
