More then 99 user defined objects?
5 replies to this topic
#1 Hubert
Hubert
Posted 03 September 2009 - 05:00 PM
I recently bought a Celestron Advanced Goto mount (CG-5).
I can store in the handcontroller 99 user defined objects. Is there a way to store more then 99 objects in it?
I'm a variable observer with about 200 stars to observe and it would be nice if I could put al the coordinates in it.
clear skies, Hubert
#2 jrbarnett
Posted 03 September 2009 - 05:53 PM
Hubert:
I don't think so. What I've had to do with my Orion Atlas EQ-G, which has only 25 User Defined Objects, is to create paper-based lists of 25 regional targets, and then manually input the desired list prior to the observing session. It's a nightmare, but because the Atlas has no "slew-to RA and Dec" command, it is a necessary evil.
On the other hand, the Nexstar does have a slew-to RA and Dec command. So long as you have a list of target variables with RA and Dec data, you could bypass the User Defined Object feature altogether.
#3 Hubert
Hubert
Posted 03 September 2009 - 11:27 PM
Jim,
I have indeed a list with coordinates of al my variables but it's time consuming typing them in while observing. It's faster when I can use the used defined object feature. But 99 is not enough.
clear skies, Hubert
#4 Chris Rowland
Chris Rowland
Posted 04 September 2009 - 03:41 AM
You have a number of options:
Use NexRemote; you can select a tour of your choice and you should be able to define your own.
Use NexTour; it will do the same thing.
Use NSOL
Use any of a number of scope control programs that can have any number of objects. There may be something that runs on a PDA to do this.
Hope this helps, I've not gone into this in detail but it gives a few ideas.
Chris
#5 Hubert
Hubert
Posted 04 September 2009 - 11:44 AM
Hi Chris,
thanks for the advice. I think that will be the best thing to do.
regards, Hubert
#6 JAT Observatory
JAT Observatory
    NOT a Wimp
Posted 04 September 2009 - 11:50 AM
I would suggest either buying a netbook or an ultra portable PC. Then you can either use software to control the scope or reload the handbox in the field if you need to change lists.
