How to balance nose heavy scope
4 replies to this topic
#1 Yenal
Yenal
Posted 14 September 2009 - 02:29 AM
Hi all. I use 14"Lx200R with FR+DSI+DSI Fan at the back. This setup is nose heavy so I want to balance it. Since I am new to balancing, I mistakenly purchased Meade counterweight, which didnt helped for my balancing as I dont have guidescope on the top of OTA. I need to balance the scope on-axis. Is there anybody with practical idea to do that at home? Google gives a perfect method (Peterson Engineering EZ Balance)for this but I live far away from USA to purchase it. Any idea will be appreciated.
Thank you.
#2 David Pavlich
David Pavlich
    Transmographied
Posted 14 September 2009 - 08:25 AM
Try this page.
David
#3 Yenal
Yenal
Posted 14 September 2009 - 08:54 AM
Thank you for the link David. But this is not what I need. I need to increase the weight of back of the telescope as it is nose heavy right now. I need to put a weight on an axis which passes directly at the center of the OTA.
#4 Tom and Beth
Tom and Beth
Posted 14 September 2009 - 09:23 AM
Actually, you can do the same thing by placing weights on top AND bottom.
If you don't want to use magnets because of electronics, some have used a velcro ring around the back of the scope and small bags filled with used tire weights that will cling to the velcro.
Necessity is the mother of invention. yes?
#5 Yenal
Yenal
Posted 15 September 2009 - 10:22 AM
Ring sounds good. Can you give me some links showing how it looks like?
Thanks.
