Lower Friction Mount Rings
5 replies to this topic
#1 Ross Babcock
Ross Babcock
Posted 17 September 2009 - 10:17 AM
I have a Orion 8" Newt on a GEM. When I have to reposition the OTA to get the eyepiece in a more usable position, the OTA really doesn't slide on the felt. I have to pick the OTA up out of the lower half of the rings, turn it and set it back down.
Other than paying uber-bucks for a ball-bearing ring mount, is there any other way to reduce the friction? I have considered replacing the felt with PTFE, but I don't know of any adhesive that would adhere to it.
#2 Quintessence
Quintessence
    Vendor
Posted 17 September 2009 - 12:14 PM
Ross,
There are two things that you can do that are inexpensive and tend to be quite effective. First, wax your tube with a good silicone-based automotive wax. Second, spray the felt lining in your tube rings with silicone spray lubricant.
Good luck,
Charles
#3 Ross Babcock
Ross Babcock
Posted 17 September 2009 - 12:30 PM
Charles,
Thanks for the idea. I will give it a shot and let you know.
Ross
#4 Bart
Bart
Posted 17 September 2009 - 07:47 PM
Ross,
Good luck,
Charles
What's a silicone spray lubricant? When at the store what should I look for? What about a thin film of Superlube?
While I'm asking, what car wax would you suggest?
#5 Quintessence
Quintessence
    Vendor
Posted 17 September 2009 - 08:54 PM
I've used a liquid wax called "NuFinish" to good effect. Turtle Wax and other brands make similar liquid waxes. Generally, you're looking for a wax that will be advertised as a once per year coating. These waxes buff to a very slick high-gloss.
Silicone spray is commonly available at hardware and automotive part stores. It usually sprays on as a foam but will become a dry film after a little time passes. It's basically a dry lubricant that is often used for locks, hinges, mechanisms that include electronics, and many other applications -- even zippers.
Oh -- I also once used silicone spray to kill a spider!
Charles
#6 Ross Babcock
Ross Babcock
Posted 20 September 2009 - 09:19 AM
My final solution:
I wasn't able to find a car wax with silicone, so I used NuFinish. I does buff to a very nice, high gloss shine and doesn't contain any wax.
For the rings, I used Triflow. It's the same concept silicone, 'dry' lubricant, using PTFN instead of silicone. In the preliminary testing, the tube moves much easier now. I can loosen the rings, move the tube without altering the alignment. Great tip...thanks!
Clear Skies
