My 200mm C/F Newt Project
71 replies to this topic
#1 paul11
paul11
Posted 11 October 2009 - 09:43 AM
Hi all I thought I would post a thread on how I made my 200mm F5.475 Carbon Fibre Newt. First of all I would like to say thank you to John Carruthers for all the help he gave me with the mirror, without his help I would never of finished it. The first image just shows the mandrel with 6 coats of release agent on it. I did split the mandrel so I could remove the cardboard tube in one piece but this didn’t work very well and the cardboard tube came out in many pieces.
#2 paul11
paul11
Posted 11 October 2009 - 09:49 AM
In this image I have coated the mandrel in Epoxy Resin and put on the first layer of C/F and wrapped it in peel ply.
#3 paul11
paul11
Posted 11 October 2009 - 09:51 AM
The next day I removed the PP
#4 paul11
paul11
Posted 11 October 2009 - 09:56 AM
Then I put on a 3mm layer of Coremat that I fully saturated with E/P first.
#5 paul11
paul11
Posted 11 October 2009 - 10:05 AM
These two images show a layer of C/F going over the Coremat, if you start of nice and straight that’s how you will finish up.
#6 paul11
paul11
Posted 11 October 2009 - 10:06 AM
Image 2
#7 Wes James
Wes James
Posted 11 October 2009 - 10:10 AM
Looking very good! What is Peel Ply???
#8 paul11
paul11
Posted 11 October 2009 - 10:16 AM
Then I applied one more layer of C/F and three more coats of E/P to make sure the C/F was well under the surface. Then it was outside to cut the surface down until it was even and finish it with 1200 wet n dry.
#9 paul11
paul11
Posted 11 October 2009 - 10:26 AM
When I was happy with the look of the C/F it was back into the workshop to cut the tube to length (1200mm). I set the depth on the Router, set the fence and ran it around the tube.
#10 paul11
paul11
Posted 11 October 2009 - 10:27 AM
And 2
#11 paul11
paul11
Posted 11 October 2009 - 10:58 AM
Then I applied a single coat of Blakes 2 component high gloss clear polyurethane varnish all I have to do now is to finish it off with a burnishing cream.
#12 paul11
paul11
Posted 11 October 2009 - 11:08 AM
Then I made the lid for the tube, I used a piece of hardboard for the base and cardboard for the walls and put on a single layer of C/F and finished it the same as the tube. To remove the cardboard and hardboard from the C/F I just put it in a bucket of water for a few hours.
#13 paul11
paul11
Posted 11 October 2009 - 11:09 AM
lid
#14 paul11
paul11
Posted 11 October 2009 - 11:15 AM
Lid on tube
#15 paul11
paul11
Posted 11 October 2009 - 11:53 AM
Hi Wes the peel ply is an extremely strong material that you can pull tight over the C/F to give a very even finish. It allows any excess glue to pass through it. The only thing is it gives a matt finish so I didn’t use it on the final layer of C/F I just let it dry on it’s own.
#16 paul11
paul11
Posted 11 October 2009 - 02:42 PM
Now for the mirror cell, for this I laminated 3 layers of Coremat and 4 layers of C/F. I made this up between 2 pieces of 6mm glass.
#17 paul11
paul11
Posted 11 October 2009 - 02:44 PM
Then I put some weight on it and left it overnight and then made a second one.
#18 paul11
paul11
Posted 11 October 2009 - 02:47 PM
With a simple jig the band saw cuts perfect circles every time.
#19 paul11
paul11
Posted 11 October 2009 - 02:50 PM
Here’s a close up of the edge of the disc.
#20 paul11
paul11
Posted 11 October 2009 - 02:56 PM
Here are the 2 discs, both 10mm thick and top disc on the left has the brass threaded inserts for the adjustment bolts.
#21 paul11
paul11
Posted 11 October 2009 - 03:01 PM
This is the bottom disc it is matt finish on this side and gloss on the other (outside).
#22 paul11
paul11
Posted 11 October 2009 - 03:05 PM
1 more
#23 paul11
paul11
Posted 11 October 2009 - 03:06 PM
with the 9 points and posts
#24 paul11
paul11
Posted 11 October 2009 - 03:07 PM
with the mirror
#25 paul11
paul11
Posted 11 October 2009 - 03:08 PM
mirror and outside posts
