EQ-6 Pro/Atlas
86 replies to this topic
#76 alpal
alpal
Posted 21 January 2010 - 10:41 PM
All sounds great now.
Apparently the manual will be updated soon to reflect
all the new menus etc.
#77 Kenny2004
Kenny2004
    Vendor - Icodome
Posted 22 January 2010 - 09:20 AM
OH well...I have the old board and don't have the Polarscope brightness - double checked.
#78 neptun2
neptun2
Posted 22 January 2010 - 02:28 PM
I am with heq5 upgraded to pro using upgrade kit and do not have the option to control polar scope brightness. Good news is that at least for me i also do not need to adjust it because it is bright just enough to hide every other star except polaris which makes polar alignment very easy.
#79 m2434
m2434
Posted 22 January 2010 - 07:17 PM
Glad to hear you got it working alpal. I'm 99% sure the "motor controller" version is the control board people were referring to. Yours is listed as 2.03. Mine is listed as 1.something so it dosn't work...
#80 alpal
alpal
Posted 22 January 2010 - 09:55 PM
I think you can buy the latest board & retrofit it.
If not a potentiometer or resistor would be easy to add
in series.
I am an electronics tech/engineer so maybe it's easy for
me & not others.
I am just glad I had the latest board.
I am still really pleased with my NEQ6.
It's great to be able to download & install the latest software
in just a few minutes.
#81 rmollise
Posted 23 January 2010 - 09:14 AM
in series.
You probably could...but go to that trouble and expense for a _polar scope illuminator_? No this ol' boy. If'n I don't like the illumination level of the polar scope, I find it pretty derned easy to shine a variable brightness flashlight obliquely down the objective end of the polar scope and make everything More Better Gooder. :lol:
#82 Starhawk
Starhawk
    Space Ranger
Posted 23 January 2010 - 01:11 PM
I'm not sure why so many folks are spun up about this polar scope business in any case. The best it can do is a mediocre alignment, so you're doing drift, anyway. In fact, I just pulled a polar scope from a Vixen mount to make a handy cable-way.
-RIch
#83 John Fitzgerald
John Fitzgerald
    In Focus
Posted 23 January 2010 - 01:16 PM
-RIch
On the contrary, I have achieved a VERY good polar alignment using only the polar scope on my Atlas mount.
#84 Skylook123
Skylook123
Posted 23 January 2010 - 03:43 PM
Me, too. With a careful polar alignment at night on my Atlas, I've kept the Sun centered in a 1 degree FOV eyepiece the next day for four hours with barely discernable drift.
The trick for me is to make sure the polar scope is truly collimated to the optical axis of the mount, and the scope is collimated to the mount axis as well (cone error elimination).
#85 m2434
m2434
Posted 23 January 2010 - 05:21 PM
Re: buying new board - probably wouldn't bother. Cheaper options seem to work fine.
Re: polar alignment - the polar scope is nice and quick and if you spend some time calibrating it on say, a cloudy night, it can be quite accurate. If I am imaging < 10 minute subs I don't see any reason to drift align. The polar scope works just fine, why waste the time?
#86 Starhawk
Starhawk
    Space Ranger
Posted 24 January 2010 - 12:49 PM
Longer focal length, higher resolution cameras, long image sequences- these will show what's wrong with a polar scope alignment.
And it's not like I haven't spent time on this: I even made a special polar alignment scope alignment target to get precise centering of the polar alignment scope with the telescope axis. For those of you inclined to polar alignment scopes, I have included it here.
But this business about not being quite happy with the alignment scope's LED seems a bit like not being totally happy with the rear window washer on your car- if it works perfectly, it doesn't really work that well, anyway.
-Rich
#87 Zoeff
Zoeff
Posted 24 January 2010 - 09:18 PM
On the NEQ6...
Setup Menu -> Handset settings -> PolarScope LED
Ah, THERE it is! Thanks! :bow:
