Great $60 Case for CPC 1100
152 replies to this topic
#1 jkf398
jkf398
  • Loc: Houston, Texas
Posted 06 January 2010 - 10:55 PM
Hey Guys -
If the thought of a $500+ case to transport your CPC1100 is just a little too much to bear, take a look at the Stanley ProMobile Job Chest from Home Depot. It's $60 US and fits the CPC 1100 exactly. The case is made of high-strength resin - so strong you can stand on it without bending it -- and it comes with a locking lid and two extra holes for your own additional locks! It also features two strong wheels and a retractable handle. Inside, there's room for about 2" of foam in all directions to protect your scope from rattles and bumps. It's 37 7/8 X 22 3/4 X 23 1/4". Take a look at www.stanleyworks.com and save a ton of money on the "alternative"!
#2 reddog15
reddog15
  • Loc: Wyoming
Posted 07 January 2010 - 12:49 PM
Nice, Welcome to Cloudy Nights :grin: Thanks for the link
#3 astrovienna
astrovienna
  • Loc: The NoVa White Zone
Posted 07 January 2010 - 03:54 PM
Thanks! I was actually thinking of building a wheeled plywood box, and this is far better. It's twice as much on Amazon. Guess I better grab one before HD realizes!
Kevin
#4 mike174
mike174
  • Loc: Central, NJ
Posted 07 January 2010 - 04:04 PM
CAn you show us a picture of your CPC1100 in the case?
Tnx,
mike
#5 jkf398
jkf398
Posted 07 January 2010 - 09:27 PM
I'll get a photo when I get a chance. It's a fabulous fit... about 2" in each direction to allow for rubber foam. The scope lies down in it.
#6 KerryR
KerryR
  • Loc: Mid-West Coast, Michigan
Posted 07 January 2010 - 10:56 PM
Where will you get your foam rubber?
#7 Edward E
Edward E
  • Loc: Tucson, Arizona
Posted 08 January 2010 - 10:32 AM
How about the foam the telescope came packed in?
#8 mike174
mike174
  • Loc: Central, NJ
Posted 08 January 2010 - 11:55 AM
I'm going to get it but I think I would use it either for long term storage or for transporting because i leave my CPC11 on the Tripod so I can easily move it when I'm going to observe. With it in the chest it will be harder to take it out because of it being lower to the ground.
CPC11/70's C8/ST80/Meade 70mm Walmart special/7x50 Pander Binos
#9 Arizona-Ken
Arizona-Ken
  • Loc: Scottsdale, Arizona
Posted 08 January 2010 - 07:15 PM
I bought a case this afternoon and am working with it.
Tried Home Depot on line to see if my local store had it, and it did not come up; however, I made an actual visit to the tool section at the store and two cases were there, with a case at $59.97 plus tax.
The diagonal and finder scope need to be removed to get the scope in the case. I am experimenting with some old camping bedroll foam and it seems to be working. When the case's handle is extended for pulling, the end closest to you is where I have the focuser/diagonal and is what I call the top. I put the base side of the scope by the wheels and call this the bottom. In this way, when pulling the case, the weight of the scope is at the scope's base and the wheels. Right now when packing I have to raise the scope slightly to get some foam in on the top side (focuser/diagonal side) and some foam just slips in on the bottom (base) side.
The handle is very nice as it is metal and extends from its slots on the outside of the case.
I'm going back to experiment a little further and will try to post some pictures tomorrow.
It looks like a good inexpensive solution.
Arizona Ken
#10 Arizona-Ken
Arizona-Ken
Posted 11 January 2010 - 09:20 PM
Pictures!
The Stanley Case for the CPC 1100. Took it out Saturday to my club's local star party and it worked like a charm. However, needs two people to get it in and out of an Explorer. Am working on that too.
Arizona Ken
#11 Arizona-Ken
Arizona-Ken
Posted 11 January 2010 - 09:21 PM
With the handle extended
Arizona Ken
#12 Arizona-Ken
Arizona-Ken
I wonder what's inside?
Arizona Ken
#13 Arizona-Ken
Arizona-Ken
Posted 11 January 2010 - 09:23 PM
Holy Smoley, it's a CPC 1100!
Since these pictures, I've made adjustments to the foam. It's a tight fit but it works.
Arizona Ken
#14 Train32
Train32
  • Loc: Washington State
Posted 11 January 2010 - 09:31 PM
Thanks for the pics Ken. I'm convinced this is the way to go.
- Shane
#15 Digital Don
Digital Don
  • Loc: Manteno, IL
Posted 11 January 2010 - 09:52 PM
"However, needs two people to get it in and out of an Explorer. Am working on that too."
I think if you can lift it alone, you get to run for governor of California... but I'm not sure! :lol:
Don :usa:
#16 astrovienna
astrovienna
Posted 11 January 2010 - 09:54 PM
Thanks for the pix, Ken! I picked up one of these this morning. Is there space to get some foam in under the base and at the top? (I'd check with my own CPC11, but it's at Celestron for a GPS repair.) And can anyone suggest what kind of foam to use, and where you can find it? Wow, a $60 case!
And thanks to jkf398. What a great first post!
Kevin
#17 Arizona-Ken
Arizona-Ken
Posted 11 January 2010 - 10:06 PM
Kevin, the foam you see in the last picture is old camping bedroll foam that I have. I use it as a sheet that lines the two sides and the bottom, and then put another piece on the top. A separate piece at each end, and away she goes.
With the foam in there, the fit is tight and the scope will not move at all.
Don, as I will never be mistaken for the "Governator" I am thinking about some sort of ramp type system for one man operation. However, two people lifting the scope and case is not difficult at all.
Arizona Ken
#18 jkf398
jkf398
Posted 12 January 2010 - 12:31 AM
Hi Guys - It's me again (jkf398, also known as "Kevin"). OK - I told you about your storage solution. Now, here's the foam-rubber solution. Go to So-Fro or Hancock Fabrics (or a similar store) and buy their 2" thick foam rubber; it will be about $20. a piece that's 4' X 2' will wrap nicely around your scope and will enable a tight lid seal. No shocks will intrude and no rattles will annoy! Enjoy.
#19 eyeowe
eyeowe
Posted 12 January 2010 - 12:40 AM
It looks as though this Stanley Case is even a little more
water resistant than the JMI Case as the half-lap lid on the Stanley looks as though water will shed to the outside, on the JMI Case the lid sits in a troff that cannot shed to the outside but rather will leak inwardly.
This is a 500% better case than the JMI......great find. And easily a $400 savings..........wow
#20 grao
grao
Posted 12 January 2010 - 03:06 PM
Thanks for the tip- picked it up and found a nice Aluminum box for $25 in the same section that is perfect for eyepieces and accys.
#21 horten7
horten7
Posted 16 January 2010 - 10:30 PM
I Just recently purchased a CPC 1100 and was looking at JMI cases to store it in but always hesitated because of the price. I will go to Home Depot tomorrow to see if I can pick one of these up.
#22 teskridg
teskridg
  • Loc: PA
Posted 17 January 2010 - 04:05 PM
Along the lines of this case, is there one suited to a CPC 800 availble somewhere? Thanks, Tim
#23 Digital Don
Digital Don
  • Loc: Manteno, IL
Posted 17 January 2010 - 04:53 PM
Hi Tim,
I use a Rubbermaid container to transport my CPC 800. Cost $20 at the local home improvement store.
It has wheels and built in handles and I wrap a 'moving blanket' around the scope for protection. The scope fits perfectly. Plus, when not transporting the scope, I store the tripod in it.
Don:usa:
#24 teskridg
teskridg
  • Loc: PA
Posted 19 January 2010 - 07:58 PM
Thank you for this information. I had hoped that a case similar to the Home Depot on might be available in a size suitable for the CPC 800. Tim
#25 Lord Beowulf
Lord Beowulf
  • Loc: Cedar Park, TX
Posted 19 January 2010 - 08:19 PM
Yeah, that's a great case. I'm up to three of them! You can see my original case setup for my NexStar 8SE here. My current setup for my CGEM and OTAs is here.
Beo
