Vixen GP brass worm gear bent
10 replies to this topic
#1 cepeter
cepeter
Posted 22 January 2010 - 03:32 PM
Anyone know where I can get a new one? Thanks.
#2 rjsc2000
rjsc2000
Posted 22 January 2010 - 03:53 PM
how bent is it? can you post a picture of it? What effect does it has on the movement of the mount?
#3 rjsc2000
rjsc2000
Posted 22 January 2010 - 04:13 PM
You can try the Vixen representant in the states? It's closer to you right? I think he's name is Mike Folwer??
#4 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 22 January 2010 - 04:20 PM
You should probably also contact Tele Vue. They were the Vixen importer for several years and have various new-old-stock parts and pieces at clearance prices. You might get lucky.
#5 SteveG
SteveG
Try this guy:
http://telescope-warehouse.com/
#6 cepeter
cepeter
Posted 22 January 2010 - 08:48 PM
The bend is quite subtle; I may be able to post a pic later. It causes the plastic gear to bind with that connecting it to my drive's motor. The gears don't meet flush. So the drive doesn't work, and manual advancement produces a "hiccup", where a couple turns of the knob produce no movement, followed by a big jump.
#7 scope dog
scope dog
Posted 24 January 2010 - 09:30 PM
Try a local machine shop. They might be able to bend it back or drill the shaft out and press, or tap/set-screw combo onto a new shaft in. Most worms shafts are just the gear with a few set screws.
#8 Patrick
Patrick
Posted 25 January 2010 - 12:55 AM
The Vixen US importer is Vixen Optics. You might give them a call.
Patrick
#9 cepeter
cepeter
Posted 18 February 2010 - 01:58 AM
Found a new RA gear assembly and am now back in business. Thanks to everyone who posted!
#10 rjsc2000
rjsc2000
Posted 18 February 2010 - 04:10 AM
how did you found it? bought from vixen? how much?
In you signature you mention'Vixen R-150S 150mm modified Newtonian/GP-Trim'. What is it?
ricardo
#11 cepeter
cepeter
Posted 18 February 2010 - 12:59 PM
I had some difficulty in getting various suppliers to respond to my inquires, but someone on Astromart was selling a new replacement part. I think I paid $35.
Some info on my telescope can be found here: http://www.vixenamer...130S_GPTRIM.pdf
