Can't Balance CGEM In DEC
4 replies to this topic
#1 Jeff55
Jeff55
Posted 28 January 2010 - 05:44 PM
Note my hardware below...my mount easily balances in RA BUT as much as I move the scope back and forth on the mounting rail my C9.25 with Megrez 90 guidescope will not balance in DEC....any suggestions before I tear my hair out.
#2 rmollise
Posted 28 January 2010 - 05:49 PM
Not that unusual. If you can't move the guidescope far enough forward (or back) to balance in dec, you can add some small weights (with Velcro or whatever) where appropriate. Keep in mind that precise dec balance is usually less important than RA balance.
#3 highfnum
highfnum
Posted 28 January 2010 - 10:02 PM
thx for posting this - I had same issue
#4 Remi2306
Remi2306
Posted 17 February 2010 - 09:03 AM
I purchased the following from Losmandy. It mounts on the bottom dovetail without having to add a rail. Works like a charm!
DWS $85.00
Dovetail adapter with a 5 inch long threaded stainless steel shaft and 5 lb weight. Mounts to D series dovetail plates, is used for the balancing of a fork mounted telescope. Wt. 6 lbs. total.
#5 Jeff55
Jeff55
Posted 17 February 2010 - 10:34 PM
It balances the DEC on my CGEM...without the DDWS it would be impossible.
