Celestron software in the CGEM
9 replies to this topic
#1 SanDiegoPaul
SanDiegoPaul
Posted 31 January 2010 - 07:42 PM
What gives with it requiring SAO numbers when you are trying to send it to a star? Why doesn't it accept normal, standard star names such as Deneb, Sirius, etc?
Is there a patch you can apply, that will change this default to SAO? :help:
#2 SchrödingersCat
SchrödingersCat
Posted 31 January 2010 - 07:56 PM
select the list button and choose your catalog
#3 SanDiegoPaul
SanDiegoPaul
Posted 31 January 2010 - 08:04 PM
will that effect the STAR menu option?
#4 DaemonGPF
DaemonGPF
    Redonkulous
Posted 31 January 2010 - 08:18 PM
You can look up named stars instead under List, Named Stars.
#5 BlueGrass
BlueGrass
Posted 31 January 2010 - 08:23 PM
No it won't change that menu. One thing that will get you to anything you're interested in, is to use an astro program such as Cartes. That's my preferred program. It interfaces with the CGEM and also helps during centering while taking frame and focus exposures.
#6 SanDiegoPaul
SanDiegoPaul
Posted 31 January 2010 - 08:29 PM
I actually have it set up with The Sky 6 Pro. I can always slew using that, but there are times when you want to send the scope to a star without using the PC. That list feature is great but cumbersome when compared to just being able to go to a star by looking up it's name in a stars-only catalog.
#7 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 31 January 2010 - 08:37 PM
There is a stars-only catalog by common name. I think you just haven't found it yet.
#8 Eddgie
Eddgie
Posted 31 January 2010 - 08:46 PM
The "Star" button only accepts SAO catalog star numbers (and there are many many thousand). You need the Named Star list.
Press the "List" button.
The window will show some kind of object catalog (it is in alphabetical order).
Use the 6 (Up) and 9 (Down) button to scroll the catalog list to "Named Star" and press the Enter button. The last star name that the telescope slewed to will show in the list.
Use the 6 and 9 button again to move from the current star name in the window to the star name you want, then press Enter. The scope should slew to the target.
#9 SanDiegoPaul
SanDiegoPaul
Posted 31 January 2010 - 11:03 PM
Eddgie & John thanks a million. I will find it if it's there!
#10 rmollise
Posted 01 February 2010 - 08:48 AM
"List" button, then select "Named Stars." ;)
