Which?
8 replies to this topic
#1 bkushner
bkushner
Posted 01 February 2010 - 09:32 PM
Celestron CGEM Mount
Orion Atlas
#2 David Pavlich
David Pavlich
    Transmographied
Posted 01 February 2010 - 10:22 PM
Capacity wise, they're the same. The Celestron has a better controller. However, you can control the Atlas with EQMOD. The Atlas is a proven performer since it's been around so long.
So...if you want to use the hand controller exclusively, I'd go with the Celestron. If you want to control it with a laptop, I'd go with the Atlas and EQMOD.
David
#3 guyroch
guyroch
    Vendor (BackyardEOS)
Posted 01 February 2010 - 11:56 PM
Take a look at this thread, more particularly John J. analysis and torque analysis half way down the conversation. I just bought the NEQ6 (Atlas twin) 2 weeks ago , EQMOD made it a easy choice for me.
#4 therocksal
therocksal
Posted 02 February 2010 - 12:25 AM
eqmod!!!!
#5 vinnie
vinnie
    Minister of Misinformation . . . Oh Yes
Posted 02 February 2010 - 12:49 AM
I have one of the first, if not the first EQ6 (Atlas) mounts ever brought into Aus. It was a special import, not off the shelf. GoTo wasn't available then (well at least no GoTo EQ6) but it has subsequently been upgraded.
Its carried everything from a 10" Newt down to an 80mm refractor, Side by sides, piggybacks, CW's completely covering the entire CW shaft. No "Coffee grinder" noise. Just recently there's a bit of slop in the Dec axis. I keep telling myself that its time to either strip it down and refurbish or move on, but the bugger keeps on going.
Re the CGEM I can't say. Never used one. I can say that you can load up an EQ6 to maybe 30 to 40 lbs for visual and expect to get at least 10 years without any maintenance at all.
#6 nemo129
nemo129
Posted 02 February 2010 - 12:10 PM
David
Don't forget that Celestron gives you their NeXRemote software with the CGEM. I have played with it on a laptop indoors and will most likely not start using it steadily until I have mastered the CGEM using just the hand controller. One thing I like is that it talks to you. I have never used EQMOD, but I have read good things about it.
I found this review of the Atlas to be useful link.
I went CGEM because of the discount you get when buying an EdgeHD with the CGEM...otherwise I was serioulsy considering the Atlas. Someday though, I want a Losmandy HGM Titan! :grin:
#7 EricJD
EricJD
Posted 02 February 2010 - 01:40 PM
Six weeks ago I switched from an LXD75 to a used Atlas. I downloaded EQMOD and Stellarium and learned how to use both. I was amazed, literally. The fit, finish, durability, spot on go to's, ease of alignment and tracking accuracy were all a dream. I went from an hour setup and still throwing away most of my subs to half an hour and keeping them all.
Can't speak to the CGEM.
#8 SKYGZR
SKYGZR
Posted 03 February 2010 - 02:01 AM
Did the same thing..upgraded from an LXD55 to an EQ-G..still sitting in the living room, hooked up to the 'puter..playing with it..too cloudy/rainy to move it to the Observ. Will get around to it, but for now, kinda fun just to play, goof off, pretend..at least it's "comfy and warm".
#9 m4ilm4n
m4ilm4n
Posted 03 February 2010 - 05:58 AM
I went through the same questions just last month looking to supplant my old SVP. The CGEM looks really solid, but EQMOD sold me on a Atlas. Once I'd hooked it up with Stellarium I was convinced it was the right choice for me.
