Mars 2/7/10, 100mm refractor
8 replies to this topic
#1 mathteacher
mathteacher
Posted 07 February 2010 - 03:13 AM
I went to an early movie tonight just to catch Mars at the right time. I was pretty lucky because as soon as I finished the sketch, clouds rolled in. Most of the sketch was done with a light yellow #12 filter. I finished with the light blue #82A to see if I would catch more details. There was a cloud on the preceding limb and there appeared to be a light band across the equator. Mare Acidalium and Niliacus lacus appeared to form a "Z" shape and I saw a dark band extend from them in fleeting moments. Checking the Calsky simulation revealed no such feature, so it may be an error on my part. Anyhow, I'm glad I got to observe for about an hour. It's good therapy.
#2 Jef De Wit
Jef De Wit
Posted 07 February 2010 - 05:26 AM
Nice sketch. I like the way how you sketch the subtle differences in albedo on Mars.
When I see all those Marssketches I have the impression it is easier to draw the planet in black/white than in colour. I find it far more difficult to put the differences in albedo on paper with colour pencils.
#3 Kris.
Kris.
Posted 07 February 2010 - 06:55 AM
good sketh Ging-Li, especially using a rather small aperture scope! i've seen the Z-shape as well :) the light band across the equator would be Chryse & Xanthe if i'm correct. some images do seem to show a lighter region or clouds on the following limb, which is left on your drawing.
Jef, it's 'easier' to sketch in B&W, i just mean, the subtle albedo differences are easier to represent then using colours. the scanner may also reduce contrast more or less using colours...
#4 rerun
rerun
Posted 07 February 2010 - 07:25 AM
Hallo,
good sketch of the other side of Mars.When I observed Mars last time I saw the side with Syrtis Major.In this area you sketched is much more difficult to see so many details with a 4" refractor. :bow:
CS
Markus
#5 frank5817
Posted 07 February 2010 - 10:47 AM
Ging-Li,
You have recorded a beautiful view of Mars. Very nice work. :bow:
Frank :)
#6 mathteacher
mathteacher
Posted 07 February 2010 - 10:53 AM
Thanks for your replies! I just got started with sketching.... I'll try color at some point but I think it is harder, too! Color sketches of mars do look better though.
I don't have a scanner so I've been taking pictures with my cheap digital camera. I noticed the pictures lost contrast, so I adjust them in GIMP to look like my original sketch. I learned this useful skill while doing astrophotography. All these disciplines intermesh :D
#7 phxbird
phxbird
Posted 07 February 2010 - 06:17 PM
Surprisingly enough the scanner seems to record to much detail. My sketches come out looking like a newspaper picture under magnification! Nothing like the actual sketch! I probably should use Gimp in the same way to make it look more like it should!
#8 dweller25
dweller25
Posted 08 February 2010 - 03:04 AM
Great sketch,you caught the NPC indent - I have yet to see that although I have noticed the NPC has become quite dim.
#9 Special Ed
Special Ed
Posted 08 February 2010 - 07:05 PM
Nice work--very well rendered eyepiece view. The North Polar Cap is going through changes--keep watching it if you have the weather.
