Mars Observation (February 7, 2010)
17 replies to this topic
#1 CarlosEH
CarlosEH
Posted 08 February 2010 - 06:03 PM
I made an observation of Mars on February 7, 2010 under average seeing conditions (5/10, with brief moments of 7/10). The amount of detail noted was impressive and difficult to render at times due to the complexity of the features noted. I welcome any comments that you may have on my observation.
Date (U.T.): February 7, 2010
Time (U.T.): 03:30-04:30
CM (Degrees West): 019.5*-034.2*
Ls 048.3*, De 013.5*, Ds 018.3*, p 100%, 13.9"
Instrument: 9-inch (23-cm) F/13.5 Maksutov-Cassegrain
Magnification: 295x and 388x
Filters (Wratten): 30 (Magenta) and 80 (Blue)
Seeing (1-10): 5 (moments of 7), Antoniadi (I-V): III
Transparency (1-6): 5
Notes:
03:45 U.T. (CM 023.2*W, Wratten 30 (Magenta)): The North Polar Cap (NPC) was brilliant (10/10) and has reduced in size (diameter) significantly compared to previous observations. The NPC was surrounded by a dark (3/10) composed of Ortygia and Mare Boreum. Mare Acidalium is visible following the central meridian (CM) and appears dark to dusky (3-4/10) with condensations noted within. Achillis Pons appeared bright (7/10) with a haze overlying it. Niliacus Lacus appeared dark to dusky (3-4) with Nilokeras (3-4/10) projecting from it's following border. Idaeus Fons appeared as a dark to dusky (3-4/10) "knob" projecting northward from Nilokeras. Lunae Lacus appears to be obscured by a very bright (8/10) haze over the following (morning) limb. Chryse-Xanthe appears bright (7/10) without detail visible within it. Xenius Fretum appears over Cydonia (7/10) as a triangular-shaped dusky (4/10) albedo feature. Sinus Sabaeus and Sinus Meridiani appear dark to dusky (3-4/10) over the South preceding (Sp) limb. Margaritifer Sinus appears a dark to dusky (3-4/10) triangular-shaped albedo feature on the CM with Oxia Palus (4/10) visible south of it. Mare Erythraeum appeared dark to dusky (3-4/10) and mottled with Pyrrhae Regio as a bright (7/10) area over it's center. Aurorae Sinus appeared dark to dusky (3-4/10) towards the following limb. The preceding (evening) and southern limb appeared very bright (8/10). The following (morning) limb appeared very to extremely bright (8-9/10).
A digital imaged produced in Pixelator.
Carlos
#2 CarlosEH
CarlosEH
Posted 08 February 2010 - 06:04 PM
04:15 U.T. ((CM 021.8*W, Wratten 80 (Blue)): The North Polar Cap (NPC) appeared brilliant (10/10). Morning (preceding) limb haze appeared very bright (8/10). Southern limb haze (SLH) appeared very bright (8/10). Morning (following) limb haze (MLH) appeared very to extremely bright (8-9/10). Albedo features were visible without much difficulty at this wavelength.
A digital image produced in Pixelmator.
Carlos
#3 CarlosEH
CarlosEH
Posted 08 February 2010 - 06:05 PM
I have labeled the major albedo features visible in my Mars observation. I hope that this helps.
The best of luck in your own observations of Mars.
Carlos
#4 Special Ed
Special Ed
Posted 08 February 2010 - 07:45 PM
Carlos,
Beautifully done. I especially like the blue wavelength. You are truly The Man. :bow: :grin:
#5 Sol Robbins
Sol Robbins
Posted 08 February 2010 - 10:24 PM
Excellent!
#6 frank5817
Posted 09 February 2010 - 01:02 AM
Carlos,
Look at that reduced North polar cap. Beautiful attention to small detail. Truly amazing for an evening of average seeing. I agree with Michael's last comment above. :bow: :cool:
Frank :)
#7 dweller25
dweller25
Posted 09 February 2010 - 01:50 AM
Superb carlos, always a pleasure to view your drawings.
#8 CarlosEH
CarlosEH
Posted 09 February 2010 - 08:26 AM
Dweller, Frank, Michael, and Sol
Thank you all for the kind compliments on my latest observations of Mars. This has been an exciting and productive Mars apparition for me thus far. I have been able to develop my digital technique on the Moon and planets. The North Polar Cap (NPC) has "shrunk" (sublimated) a significant amount over the past few weeks. The best of luck in your own observations of Mars.
Carlos
#9 rerun
rerun
Posted 09 February 2010 - 10:51 AM
Carlos,
so many details,two wonderful sketches of Mars.With your excellent labeling,I use it always to identify the places on Mars I don't know,yet.
CS
Markus
#10 markseibold
markseibold
Posted 09 February 2010 - 11:21 AM
Carlos
Beautiful rendering from your observation of Mars. :bow: :bow: :bow:
I think your excellent labeling of the surface features should go into a current display like Spaceweather, say a series of several prominent hemispheres to show the general observers in a daily frequented site like Spaceweather, so as to inform them what they could be seeing with medim telescopes and some exerted and patient observing while Mars is still close.
Mark
#11 mathteacher
mathteacher
Posted 09 February 2010 - 11:51 AM
Beautiful work again, sir!
#12 mikesemmler
mikesemmler
Posted 09 February 2010 - 01:08 PM
Thats a great job again
Michael
#13 CarlosEH
CarlosEH
Posted 10 February 2010 - 06:42 AM
Ging-Li, Mark, Markus, and Michael
Thank you all for the compliments on my latest observations of Mars. I am glad that the labeling of the albedo features helps to better understand the features being observed at this time. I will see what I can do about a series of hemispherical maps of Mars but there exists several good maps already.
Links;
http://marsprogram.j...ch/marsnom.html (ALPO Mars map)
http://alpo-j.asahik...test/map123.JPG (Ebisawa Mars map)
Carlos
#14 rerun
rerun
Posted 10 February 2010 - 11:32 AM
Hallo Carlos,
thank you for the links of Marsmaps ,very detailed maps of Mars,very useful for me.
CS
Markus
#15 Tommy5
Tommy5
Posted 10 February 2010 - 07:50 PM
Wow, each one of your digital sketches gets better and better,great accurate detail thanks for keeping us up to date on Mars until our skies clear.
#16 JayinUT
JayinUT
    I'm not Sleepy
Posted 10 February 2010 - 10:53 PM
Carlos,
Tremendous! Detail is just perfect.
#17 niteskystargazer
Posted 11 February 2010 - 12:11 PM
Carlos,
:waytogo:, nice sketch :)
#18 CarlosEH
CarlosEH
Posted 11 February 2010 - 11:29 PM
Jay, Tom, and Tommy
Thank you for the compliments on my latest observations of Mars. I think that practice with digital media and decent seeing conditions has allowed me to improve my renderings.
Markus- You are welcome. I hope that the Mars maps help you in your observations.
Carlos
