CGEM mount base
5 replies to this topic
#1 Doug76
Doug76
    Long Achro Junkie
Posted 10 February 2010 - 01:24 AM
Is it the same as the CG-5? What I mean is, would the CGEM mount itself fit the CG-5 tripod mount base?
#2 mclewis1
mclewis1
    Thread Killer
Posted 10 February 2010 - 08:40 AM
Doug,
No, not the same as the CG-5 ... the CGEM is the same as the Atlas/EQ-6. The tripods have the same legs and look similar but the size of the round inset area at the top of the tripod is not the same.
#3 RTLR 12
RTLR 12
Posted 10 February 2010 - 08:43 AM
Yes and no... The center "pilot" hole is larger on the CG-5, but you could probably still center the mount, and the DEC locating pin is too short, but you could change that. The tri-pods are identical.
Stan
#4 jrbarnett
Posted 10 February 2010 - 11:23 AM
Nope.
CGEM mount base = Atlas mount base
CG5 mount base is incompatible.
If you're concerned about getting enough saddle height for a long refractor, the Atlas pier extension works with the CGEM tripod.
#5 Doug76
Doug76
    Long Achro Junkie
Posted 10 February 2010 - 06:58 PM
No, thinking about having to make a new mounting for my pier to have to hold either the Atlas or the CGEM. Hoped I wouldn't have to.
#6 Doug76
Doug76
    Long Achro Junkie
Posted 11 February 2010 - 10:22 PM
Looks like the extension post for the Atlas is the same diameter as the SVP post. This greatly simplifies my altering the present CG-5 mount adapter I have on the pier.
