Mewlon 250 on AP 600E
4 replies to this topic
#1 chuckscap
chuckscap
Posted 12 February 2010 - 08:24 AM
Hi will an AP 600E mount handle a Mewlon 250 for visual observing and "light" imaging? I have no plans to piggyback anything on my Mewlon, I may do some prime focus / short exposure imaging (1 min or less) with my modified Canon 300D, but it's not my primary objective.
Chuck
#2 galacticphoto
galacticphoto
Posted 12 February 2010 - 10:57 AM
I used my CGE w/ the Mewlon for several shots. The MI provides a higher exposure success rate, but the CGE worked, so I'd bet the 600 also will work.
The real question is whether you really want to run the small image scale that you'd have w/ the DSLR on the Mewlon (@ native FL). I bin X2 (w/ a monochrome cam) when imaging on the Mewlon, to keep the scale up to a manageable value (0.9"/pix). This allows reasonable exposures in 5 or 10 minutes.
Robert
#3 zawijava
zawijava
Posted 12 February 2010 - 11:12 AM
Chuck
I had my M250 on a Tak EM200 and it was a very good match for visual. I think the 600E would be fine as well.
Tim
#4 Tom and Beth
Tom and Beth
Posted 12 February 2010 - 11:36 PM
Actually, that would also depend on the PIER. FWIW, I found that a TEC 140 and TV76 piggybacked (about your mass but more moment arm) was OK, but I was on a 10 inch column of re-inforced concrete.
The 600 is a great mount, but make sure you have a solid pier or set of legs with that load.
#5 chuckscap
chuckscap
Posted 13 February 2010 - 07:56 PM
Thanks all,
Chuck
