Mars - 16th February 2010
11 replies to this topic
#1 dweller25
dweller25
Posted 16 February 2010 - 04:06 PM
Mars - 16th February 2010, 19:45UT
8" F/6 Newtonian at x300.
Seeing II - very steady
CM = 178'
Lots of high thin cloud around that I was able to view through and that seemed to help with the view !!
Very definite darker areas in the middle of Mars with lots of brighter regions to the east and west - more subtle than my drawing skills though !!
For the first time ever I managed to see the Hyblaeus extension - more as a difference in brightness between two regions, very subtle indeed.
Considering this is the quiet side of Mars I found a lot to see and draw helped by unusually good seeing.
#2 frank5817
Posted 17 February 2010 - 01:58 AM
dweller,
Very nice, the good seeing makes all the difference.:waytogo:
Frank :)
#3 niteskystargazer
Posted 17 February 2010 - 11:48 AM
Deweller,
:waytogo:, Nice sketch :).
#4 mathteacher
mathteacher
Posted 17 February 2010 - 12:19 PM
Congratulations on the Hyblaeus extension. Mars is fading fast!
#5 Kris.
Kris.
Posted 17 February 2010 - 01:50 PM
very nice sketch of the 'dull side of mars' dweller. i think though that you mean Elysium instead of the hyblaeus extension, wich i think is the dark area under and left of syrtis major, and would not have rotated in view by the time of your sketch. elysium is a nice catch, because it looks much dimmer than some time ago imo!
#6 dweller25
dweller25
Posted 17 February 2010 - 03:19 PM
Thanks for all the kind comments.
Kris thanks for the correction but is Elysium a large light area ?? I saw a long dark area.
D25
#7 Kris.
Kris.
Posted 17 February 2010 - 03:29 PM
Yes Elysium is a light area, so perhaps you saw Phlegra or Aetheria? but i leave it to Carlos to make the correct correction ;)
#8 dweller25
dweller25
Posted 17 February 2010 - 03:44 PM
LOL - I'm sure your right, I have no idea :foreheadslap: !!!
As you say Carlos will know :bow:
#9 Jef De Wit
Jef De Wit
Posted 17 February 2010 - 04:48 PM
Dweller
Nice to know that the weather was good for Mars observing. I had also a a nice view of the planets "bad side". I can't help you with the Hyblaeus Extension, but I think I saw it two hours later than you (see my post).
Why is your sketch blue? Is it of the high clouds?
#10 dweller25
dweller25
Posted 17 February 2010 - 05:40 PM
Jef - It's a black and white pencil sketch that did not scan well !!!
(I should have said I used a blue filter - LOL )
#11 Tommy5
Tommy5
Posted 17 February 2010 - 08:35 PM
very good sketch of mars duller side, i often find that a high cloud layer improves my view of Mars and Jupiter, perhaps it is because the air is so still, or it helps reduce the ca in my achro refractor.
#12 CarlosEH
CarlosEH
Posted 18 February 2010 - 12:01 AM
Dweller,
An excellent observation of Mars. Elysium is the light area over the center of the disk. At times a cloud is visible over this region which makes it easier to distinguish. Thank you for sharing it with us all.
Carlos
