Photoshop hints?
2 replies to this topic
#1 mandotrout
mandotrout
Posted 20 February 2010 - 11:57 AM
Can anybody tell me how, or direct me to an online tutorial, to create a template in PS for my sketches that includes a perfect circle for the sketch and a place for entering text to describe the object, equipment, conditions, etc.: something similar to what I see on so many of the great sketches on this forum. I'm not having any luck figuring it out on my own.
Jeff
#2 BillP
BillP
Posted 20 February 2010 - 12:22 PM
I don't know if there is a tutorial some place, but basically each item is a layer and each layer you manipulate independently. So in my template there is a layer for the sketch, then a back bacground layer, then a black mask layer with a central portion that has a perfectly round hole to view the sketch thru in case it was not perfectly round when I sketched it, and seperate layers for each segment of text, like the header, footer, etc. So you need to have the layers window showing - it's in the pull down menu where the Show Brushes is. They whatever layer is hilighted is what you will be modifying when working. If you want, send me a PM with your email address and I'll send you my Photoshop template so you can use, modify, or experiment with.
#3 mandotrout
mandotrout
Posted 20 February 2010 - 12:49 PM
Thanks Bill, that's exactly what I was looking for. I'll send you a PM.
Jeff
