Astrotech 72 vs Megrez 72 vs Stellarvue 70ed
14 replies to this topic
#1 josephpcorallomd
josephpcorallomd
Posted 25 February 2010 - 06:36 AM
Hi all:
I'm looking to purhase either an astrotech 72, wo megrez 72, or stellarvue 70ed to use as a travel scope/widefield scope, finder for my 12" dob, and occasional astrophotography. Any suggestions, recommendations, or personal experiences with these scopes you could share with me?
Joe
#2 Cyclop_si
Cyclop_si
Posted 25 February 2010 - 06:43 AM
I would buy based on a price. I think optic is more or less the same.
#3 justiceandjordan
justiceandjordan
Posted 25 February 2010 - 08:49 AM
Since its going to be used for widefield/finderscope, get the one that has the shortest focal length, and throw in a lens which gives you the widest TFOV.
Optically, they will all be on par with each other.
#4 josephpcorallomd
josephpcorallomd
Posted 25 February 2010 - 09:23 AM
Thanks for the replies so far. My main question is performance differences between the scopes. I know that all stellarvues are hand figured and personally tested prior to shipping. I don't know that the same is true for astrotech as there is nothing specifically stating that on their website. I don't really care about the price difference b/w the scopes, if there is a slight edge for one.
Joe
#5 Preston Smith
Preston Smith
    The Travel Scope Guy
Posted 25 February 2010 - 09:29 AM
I believe there are differences in the focusers. I have the SV70ED and have been very pleased with the performance of the focuser on it. I can hang a 2" diagonal and a heavy eyepiece on the small scope with no problems. Very smooth and the two speeds work great.
#6 Astronomics
Astronomics
    Vendor: Astronomics
Posted 25 February 2010 - 09:52 AM
Every AT refractor is tested prior to shipping.
#7 Lt 26
Lt 26
Posted 25 February 2010 - 10:42 AM
Joe, we have a SV70 and quality of this thing is quite surprising for the cost. Nice glass and great focuser.
Dereck
#8 jason_milani
jason_milani
Posted 25 February 2010 - 11:18 AM
Joe
SV might star test every one but and they may be hand figured but they are hand figured at the factory - not at SV. It's the same factory that puts out all the similar one's you mentioned.
#9 Yedgy
Yedgy
Posted 25 February 2010 - 12:30 PM
I used to own an SV70ED and can vouch for its quality. The focuser is rotatable and is very solid despite a fairly long drawtube travel distance. It also has a nice, solid screw-on aluminum dustcap for the objective.
Tony
#10 David E
David E
Posted 25 February 2010 - 01:12 PM
Here is a user report I did on my SV70ED.
#11 jetsfan122
jetsfan122
Posted 25 February 2010 - 01:45 PM
You may want to check out Orion's EON scopes . I have the 80 mm and it is sharp looking , very well made and gives outstanding views . My neighbor has the Stellarvue 80mm and the two are very comparable .
#12 JadeSmith
JadeSmith
Posted 27 February 2010 - 10:36 PM
I have had good luck with Stellarvue and AstroTech.
Nice optics...nice focusers...great customer service.
#13 Doug76
Doug76
    Long Achro Junkie
Posted 27 February 2010 - 11:14 PM
All my Astro Techs have been A-1. Highly recommended.
From Vic Maris himself I know the SV70 has the best focuser of them all.
I have no knowledge of the WO, but assume it is comparable to the others optically.
#14 soupaman
soupaman
Posted 28 February 2010 - 08:38 AM
Hi Joe,
As a finder on your dob you're gonna need at least 10 pounds of counterweight. That's if you're mounting it on the upper cage. I've done this with many small refractors including a TV 60 and the extra weight makes a fairly big difference in the dobs motions.
#15 Don Trinko
Don Trinko
Posted 28 February 2010 - 12:33 PM
I have the Astrotech 66mm. It is excelent opticaly and mechanicaly. I love the 2 speed focuser. Don T.
