I just got mine, too! (Yet another AP1200 owner)
32 replies to this topic
#26 WirelessDude
WirelessDude
Posted 11 May 2010 - 02:32 AM
After getting the alt/az adjustments tuned to <2 arc-minutes on each axis off NCP, I was able to do some unguided test shots of M101, M51, M13, and M16...
Here's a cropped raw image of M16 at about 25 degrees. Keep in mind that this is a single image, dark subtracted, unguided, and exposed for 4 minutes using the ST-8300M.
I am going to have some fun with this gear! :jump:
Clear skies!!!
#27 gillmj24
gillmj24
Posted 11 May 2010 - 10:36 AM
Which scope was that the 127?
#28 WirelessDude
WirelessDude
Posted 11 May 2010 - 01:34 PM
Yep! I don't have the 14"er on the mount yet. I wanted to get used to the mount and work out the adjustments with something lighter on it...
Clear skies!
#29 WirelessDude
WirelessDude
Posted 15 May 2010 - 07:05 PM
I finally got the 14" LX200R on the mount. WOW! I wonder If I am able to get the NP127is on it with the clearance that's left over. If not, I'll settle for my Meade Series 5000 80ED Triplet APO... :)
I don't have the AO-L attached in the optical train just yet since I maxed-out the CWs with the load you see here. I have more CWs on-order.
Clear skies!
#30 WirelessDude
WirelessDude
Posted 16 May 2010 - 06:32 PM
Here another shot of the wire organization. Not quite permanent, but I made use with what I had on-hand. We'll see how it works out!
Clear skies!
#31 RobertED
RobertED
Posted 16 May 2010 - 07:07 PM
Looks like a fantastic set-up, Wireless Dude!! Very Awesome!!!...any pro's or con's encountered by you yet????
#32 WirelessDude
WirelessDude
Posted 16 May 2010 - 07:25 PM
Other than this (see attached image), everything is working like a dream! :cool:
As expected, the scope needs some collimation after a change of hands (bought it on AM and arranged for pickup between Phoenix and San Diego...)
Clear skies!
#33 WirelessDude
WirelessDude
Posted 16 May 2010 - 07:45 PM
Decided to tie the black plastic conduit tubing to the scope handle due to some potential kinking between the DEC servo motor and the DEC clutch knobs...
Clear skies!
