AP800 autoguiding question
4 replies to this topic
#1 buckeye_hunter
buckeye_hunter
Posted 09 May 2010 - 03:29 PM
I am selling my AP800 mount. A prospective buyer asked the following:
"I'm interested in the mount for wide field astro photography - do you know how well it works with an autoguider - if the motor controller has a drive rate setting of .5X sideral rate, rather than the normal
5X, 10X rates used for centering objects for visual use?"
Can anyone here help me answer the Question? If it is relevant, the mount does have a variable tracking rate. I am not sure if this translates into the question about the autoguider.
Thanks in advance for any help,
Bob
#2 LLEEGE
LLEEGE
    True Blue
Posted 09 May 2010 - 04:10 PM
Best bet is to give AP a call.
#3 BrendanF
BrendanF
Posted 09 May 2010 - 04:51 PM
From the controller, it looks to have 2x and 8x, but AP would know for sure, as LLEEGE said.
#4 buckeye_hunter
buckeye_hunter
Posted 09 May 2010 - 05:04 PM
Agreed, the controller 2x and 8x, but it also has variable speed tracking as an option. It is selected on the controller as would sidereal, solar and lunar, then the speed is set by the dial on the upper right of the controller.
Thanks for the help so far...
Bob
#5 TxStars
TxStars
Posted 10 May 2010 - 12:02 PM
I'm guessing you have not had this mount long? Correct?
Do you have this link:
http://www.company7....nts/800gem.html
Your mount can be modified to be used with an auto-guider if it was not done at the time of purchase.
