iOptron Mini Tower Pro Mount
11 replies to this topic
#1 ybor
ybor
Posted 13 June 2010 - 02:09 PM
I am looking at buying an iOptron Mini Tower Pro Mount .
I read that Mini-Tower mounts had some problems .
Have the problems on Mini-Tower been corrected on the iOptron Mini Tower Pro Mount ?
Are there any reported new problems with iOptron Mini Tower Pro Mount ?
Thank You
#2 biz
biz
    Vendor
  • Loc: New Zealand
Posted 14 June 2010 - 04:21 AM
what sort of problems are you referring to..i have both the minitower and minitower pro mounts and i dont have any problems.
#3 ybor
ybor
Posted 14 June 2010 - 07:26 AM
I was referring to the tracking & the bearings .
Thank You
#4 DoctorNoodle
DoctorNoodle
  • Loc: Lawn Guyland, NY
Posted 14 June 2010 - 10:56 AM
I have a MiniTower and haven't had any real problems. Any problems I did have were caused by my scope not being balanced and putting too much strain on the motors. Balancing the scope and re-aligning the mount fixes this.
If the mount has any true problems, they're minor quirks and have nothing to do with performance:
Noisy high-speed slewing
No accessory tray on the tripod
Loud beep by the keypad when an object is found that can't be turned off
Otherwise, I'm very happy with my MiniTower.
#5 biz
biz
    Vendor
  • Loc: New Zealand
Posted 15 June 2010 - 12:27 PM
doctornoodle..if you have a look at my photo folder (mimi-tower mods) on the minitower yahoo site you will see a tripod tray that i have put together.. its simple.
cheers.
Graham.
#6 DoctorNoodle
DoctorNoodle
Posted 15 June 2010 - 03:15 PM
I like that, Graham! Looks like it should be an easy project. Thanks! :waytogo:
#7 John Noble
John Noble
  • Loc: Sandy Eggo, California
Posted 15 June 2010 - 09:20 PM
Doctornoodle, let's all call iOptron and ask them to include a goto slew speed selection menu and a "turn the %$#%^ beep off, and I mean OFF" setting in the next firmware revision. My CubePro,which uses the same firmware AFAIK, would be nearly perfect for my uses with those two improvements.
#8 biz
biz
    Vendor
  • Loc: New Zealand
Posted 15 June 2010 - 11:57 PM
your welcome.........its real easy , only one hole to bore.
cheers.
Graham.
#9 biz
biz
    Vendor
  • Loc: New Zealand
Posted 16 June 2010 - 04:43 AM
John, i certainly agree on a menu selection for go-to speed.
cheers.
Graham.
#10 tsmith70
tsmith70
Posted 16 June 2010 - 06:27 PM
i'm able to turn the beep off on my hand controller. I have a mini tower. I can't recall exactly which screens , but one of them has a sound setting, just select off. and then it won't beep until you power it down and power it back up.
I agree, that beep is annoying.
#11 Hoppy
Hoppy
  • Loc: Illinois
Posted 22 October 2012 - 10:10 AM
My Skywatcher 120mm ED apo is a long enough OTA that it kept striking the tripod legs when operating from the park position - mount south, OTA pointing to zenith. Ioptron's solution is to "allow you" to purchase a pier which attaches to your mount essentially lifting the brains of the mount about another 10 inches, and of course, adding weight to the entire telescope. I have ordered this pier, and when I get a chance to put a couple of hours of use to it, I will post my opinion. That makes $1436.00 into this mount so far! Stay tuned. Jim Hopkins, Naperville Astronomical Association, Kankakee Area Stargazers, and the Michiana Astronomical Society.
14 inch Meade LX-200 enhanced
10 inch Meade Lx-200 ACF
120mm Skywatcher ED apo
7 Naglers and 3 Ethos Oh My...
#12 FishInPercolator
FishInPercolator
  • Loc: NYC
Posted 30 May 2013 - 01:51 AM
Have these issues been resolved?
