Astro professional 80mm ED or SkyWatcher Evostar80
7 replies to this topic
#1 Orion434
Orion434
Posted 05 July 2010 - 05:41 AM
Hello,
Is it better to buy Astro-professional 80mm ED or SkyWatcher Evostar 80mm ED. Both of them have the same price
and they are going to be used for astrophotography.
Thank you,
Clear skies
#2 Orion434
Orion434
Posted 07 July 2010 - 10:52 AM
Anyone? Pls.
Well, I know that Astro professional is very new brand but I will use it for autoguiding and maybe astrophotography so is it good enough to beat SkyWatcher EVOSTAR.
#3 Jon Isaacs
Posted 07 July 2010 - 11:59 AM
Hi:
The Skywatcher appears to be an Orion ED-80 with an upgraded focuser, tube rings etc. The ED-80 is a proven scope for astrophotography, it is essentially color free with it's FPL-53 based doublet objective.
The Astro-Professional looks to be one of the 80mm F/7 triplets similar to some of the William Optics and Astrotech scopes. The triplet objective has advantages but in this case, since they are not advertising FPL-53, I would believe it is FPL-51, how the color correction game plays out between the two, it is hard to say.
Both are similar, I would suggest going with the vendor you are most comfortable with.
JOn
#4 Orion434
Orion434
Posted 12 July 2010 - 06:55 AM
Thanks.
#5 RTLR 12
RTLR 12
Posted 12 July 2010 - 08:08 AM
FPL53 v FPL 51...Doublet v Triplet...Do you think the difference between the properties of the glass outweigh the advantage of the triplet configuration?
Stan
#6 watcher
watcher
Posted 12 July 2010 - 08:49 AM
I'm not one of the optics experts here, (maybe some will weigh in), but from many reads of past threads, I surmise that a triplet, whether fluorite fpl-51, fpl-53, or short flint, will have a better chance of focusing 3 wavelengths of light at the same point.
For visual, close enough is good, and glass type makes a difference in how close it's possible to get with 2 elements. For imaging, I would go with the triplet, as long as the focuser is as good as the doublet. I've seen some pretty nice images taken even with achros, but it's more work to get them nice.
#7 glava2005
glava2005
Posted 12 July 2010 - 06:32 PM
u guys allways get sidetracked when talikng about refractors :)
think Orion434 is asking about astro professional ED80 vs skywatcher ED80... astro professional doesn`t make 80mm triplets... think AP ED80 would be bit better for astrophotography because of it`s bit shorter focal lenght.
whichever you choose you won`t be wrong. i personally have skywatcher ED80 and the views are very nice. you should search the net for pictures taken with both scopes to help you decide.
#8 watcher
watcher
Posted 12 July 2010 - 07:04 PM
Right you are. I got suckered in by not paying attention to European offerings. :foreheadslap:
