Has anyone seen or used a Boren-Simon Astrograph?
17 replies to this topic
#1 Chris.Baron
Chris.Baron
  • Loc: Maple Ridge, British Columbia Canada
Posted 06 July 2010 - 01:59 PM
Product page
I'm a bit intrigued to say the least, but I can't see much in the way of information/user generated images from these things. Searching various places yields images taken by one of the "creators" of this scope.
Faced with this or a Tak Epsilon 180, I'd obviously prefer the Tak but my wallet would much prefer this scope. Imaging is my main/only use for this scope so I'm not worried about visual performance.
I can live with a few corners cut quality wise to save $2500.
Chris
#2 blueman
blueman
    Photon Catcher
  • Loc: California
Posted 06 July 2010 - 04:14 PM
The link is bad.
Blueman
#3 Chris.Baron
Chris.Baron
Posted 06 July 2010 - 04:19 PM
D'oh!
Fixed.
Chris
#4 Gary.McK
Gary.McK
  • Loc: Geelong, Australia
Posted 06 July 2010 - 07:19 PM
It looks like an 8" f4 GSO newt that has been fitted with a Keller corrector. These are available here:
http://www.astrosyst...correctors.html
Note that one of the correctors even has the 65mm backfocus specified in the scopes web site.
Some tests:
http://www.heavensgl...com/RC Talk.htm
Buying one of the higher spec'd correctors and putting it on a cheap newt would still be way cheaper than buying this package....
There's plenty of stuff around on Keller correctors. Just google. They are very highly thought of. I will one day buy one for my GSO newt.....especially since they can be swapped from scope to scope...imagine a 16" cheap Meade dob put on an eq mount and converted from f4.5 to f3.3 !!!!
hope this helps...
cheers
Gary
#5 Craig
Craig
    Vendor (Stark Labs)
  • Loc: Irvine, CA
Posted 07 July 2010 - 10:51 AM
Gary's hit it on the nose, I believe. The 25 mm spec (when not focused in the center) is also on target. By all accounts, these are outstanding correctors (ASA uses them). Current price is about $900 for one. Toss in the AT8IN for $450 and, from what I can tell, you have a similar rig to what's shown. ASA has some nice performance info on it:
http://www.astrosyst...oll_Reducer.pdf
In my mind, a key factor in the success of this will be keeping the tube flex out of the equation. With a heavy camera, the tube will flex, getting the corrector (and camera) out of collimation. If that's in check, then just having a focuser up to the task of f/2.8 or so. I'm not seeing anything in there to stiffen up what looks to be a normal rolled-steel tube. The end-cap there so close to the focuser helps a good bit and the tube ring placement can help a lot here too. But, this is a battle I've fought several times and it's something to be aware of.
Craig
  • PascalN likes this
#6 thrawn
thrawn
  • Loc: Los Angeles, CA
Posted 07 July 2010 - 05:21 PM
Yes, the AT8IN looks like a better 'scope for imaging.
http://www.astronomi...roduct_id/AT8IN
#7 Chris.Baron
Chris.Baron
Posted 07 July 2010 - 07:06 PM
Thanks for replying guys. Very much appreciated. I'm not sure I want to leave the realm refractor imaging, but I've been toying with the idea of a Mak-Newt or fast Newt to maximise my data capturing potential given the limited runs of clarity we get here
The Boren-Simon has a stainless steel tube, and given what you've just stated Craig I suspect it's a battle I don't feel like fighting myself. Just to clarify though, are you suggesting adding this corrector into the AT8IN to make it an F/2.8? That would be an interesting endeavour. If that's essentially what the powernewts are it could be a worthwhile one too.
Chris
#8 Craig
Craig
    Vendor (Stark Labs)
  • Loc: Irvine, CA
Posted 07 July 2010 - 07:33 PM
Looking at the specs, it's an F/4 Newt with that reducer / corrector. The baffle rings on the AT scope could be glued in place to form internal stiffeners is my guess. Get an extra set of external rings to clamp around the focuser and the tube will resist a lot of flexing. Next, have a focuser up to it and you should be in very good shape for a lot less than an Epsilon.
Craig
#9 elwaine
elwaine
  • Loc: Jupiter
Posted 08 July 2010 - 09:40 PM
Hmm... are we comparing apples to apples? The AT's optics are "diffraction limited" (which is code for 1/4 wave), whereas the claim made for the Boren-Simon is that the mirror is 1/12th wave. Personally, I don't know what, if any, difference that will make on imaging DSOs, but from what I read here on CN, it really does mater: at least for visual and for imaging planetary detail.
I do not mean to speak poorly of the AT scope, but I'm not all that certain that one can take the AT scope, insert a Keller corrector, and wind up with the same quality instrument that the Boren-Simon claims to be. It has that "too good to be true" ring to it... and I can't tell you how many times I've eventually paid twice as much by trying to save money on the initial purchase. :)
#10 thrawn
thrawn
Posted 08 July 2010 - 11:20 PM
That 1/12 wave claim is pretty shady in this price range... I bet it's 1/12th wave RMS!
Shady indeed. But I've e-mailed the question.
Edit: The GSO 8" Newt claims to have a "1/12th wave" mirror, so lets not be fooled, unless Zambuto has moved overseas.
GSO Page: http://www.gs-telesc...ntent.asp?id=79
#11 elwaine
elwaine
  • Loc: Jupiter
Posted 09 July 2010 - 05:48 AM
Suneet, I think you nailed it. Since mirrors of even a 1/7 wave PV or slightly better are difficult to come by, and are expensive to manufacture, your analysis of the 1/12 wave claim makes a lot of sense. Thank you.
A corrector can only flatten the field and lower the focal ratio. It cannot improve upon the optical quality of a so-so mirror. I'm not saying that the Boren-Simon mirror is superior to that used by AT. In fact, they may be one in the same. I have no way of knowing and no means of comparison.
But the entire cost of the AT scope (OTA, mirrors, dual focus Crayford, spotting scope and rings) is $450. So is anyone really suggesting the addition of a $900 - $1,800 Keller corrector on a $450 telescope? Perhaps the wisest thing for the OP to do is to bide his time... and save his pennies... and wait for others to review the B-S (no pun intended) astrograph, rather than consider buying a really inexpensive scope and a lot of expensive lipstick to make it look pretty. - Just my $.02
#12 waso29
waso29
  • Loc: Chi-Town, USA, mother earth
Posted 23 August 2014 - 06:43 AM
any more experiences with these rare birds?
or is tak epsilon the only game in town?
#13 gdd
gdd
  • Loc: Lynnwood, WA (N/O Seattle)
Posted 23 August 2014 - 04:21 PM
I don't see the website for the Boren Simon Powernewts anymore (are they still in business?), but I did find this:
http://www.teleskop-...Astrograph.html
People trying to modify the AT8IN to make their own "powernewt" have lots of collimation problems requiring them to beef up the OTA and focuser.
The Tak Epsilon is more expensive but I understand it is flat across a full frame 35mm sensor or bit larger, but the PowerNewt is designed for the half frame crop sensor.
Here is another fast and expensive 8 inch astrograph:
http://www.optcorp.c...escope-ota.html
Gale
Edited by gdd, 23 August 2014 - 04:34 PM.
#14 orlyandico
orlyandico
  • Loc: Singapore
Posted 24 August 2014 - 12:51 AM
I bought an AT8IN and an ASA Keller reducer.
I replaced the focuser with a Feathertouch (with motor) and reinforced the tube.  I also had to get a CatsEye XLKP because the thing is incredibly sensitive to collimation.
Short story: after eight months of futzing around I sold the Keller and got a Paracorr..  I never got round stars out of the Keller, even with OCD collimation. The tube isn't strong enough, even with reinforcing. It flexes and throws off the collimation.  I got round stars out of the box with the Paracorr.  Of course f/2.8 is not f/4.6
Also, any tilt in the CCD will cause defocus.  At f/2.8 the zone of critical focus is about 8 microns I think.  The tiniest tilt will cause bloomed stars in one corner of the CCD.  I verified this, if (one) corner was sharp, the center was not. If the center was sharp, about 20% in one corner was not.
At f/2.8 orthogonality and rigidity is everything.
On the other hand I know someone who has never collimated his Epsilon, and it still produces round stars even after bumping along back country roads.
I can't see how the Boren-Simon can be better - they are using the same tube, the same linear bearing focuser.  In theory my setup was superior (stronger tube, Feathertouch focuser) but I still couldn't tame it.
The only good news was I was able to sell the Keller reducer for a minimum loss.  But the time wasted was priceless.
#15 orlyandico
orlyandico
  • Loc: Singapore
Posted 24 August 2014 - 12:53 AM
Incidentally I got my Keller reducer from Harel Boren. So, the specs on the net imply that the Boren-Simon uses the ASA Keller reducer, my anecdote seems to confirm that.
#16 everstar
everstar
  • Loc: KS
Posted 14 January 2015 - 02:01 PM
So this was some good conversation here, as I have stumbled down the Boren Simon path to arrive at this thread in my research.
What I am reading is that they have a carbon fiber tube now and total weight on an 8" model is only 7KG and also reason why flexure is not an issue due to lighter weight.
Still, back to the OP, there are not many images out there and some that I have seen seem a little watery looking, hard to tell if its the OTA or the person making the images.
But at just 7.kg and a beafed up FT focuser with motor and corrector and reducer shipped to the US it seems like a decent deal (especially if Dollar gets stronger against Euro - remember you can divide final cost in cart by 1.19 if buying for US as we don't pay VAT) if its optically sound.  The idea that you can flip back to F/4 seems like a bonus as well.
Any new users of this or people that have tried one here that can elaborate more?
#17 psandelle
psandelle
  • Loc: Los Angeles
Posted 15 January 2015 - 10:19 AM
LOVED my 6" PowerNewt. Simple to use, put a Rigel motor and focuser on it and it focused easily, they have the carbon tube now for it (I had the steel). Was a joy. And the guys over there were helpful when needed. Used Glatter to collimate and never looked back. Of course, I had a QHY12 on there, so it was light on the focuser...can't say what a heavier camera will do, but I was thinking about getting two and mounting them in parallel, one for mono, one for OSC.
Last I touched base with Harel, he was supposedly getting the website back up...but that was a while ago. He said they were still making the PowerNewts at that time. Checkw with him or Kfir, they're usually around CN putting up pictures.
Great scope, great price, easy to image with. There was an ATT review a year and a half or so ago.
Paul
#18 akulapanam
akulapanam
Posted 16 January 2015 - 08:51 AM
Teleskop service sells a upgraded carbon fiber gso scope with the asa corrector which is effectively the same as a powernewt.
