Edge HD Focal Reducer
463 replies to this topic
#1 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 19 July 2010 - 07:36 AM
Any tried any focal reducers with their Celestron Edge HD's? I know Celestron is planning on coming out with a dedicated FR but has anybody tried using one of theirs? Would a screw-in FR work?
I find it hard to believe that they came out with a scope that is "almost" perfect for imaging but is restricted to f/10mm-f/11mm.
#2 Fred1
Fred1
  • Loc: close to the inner rim of the Orion Spur, about halfway along its length.
Posted 19 July 2010 - 07:52 AM
Actually, it's Fastar compatible, so it's not restricted to f10 as the Fastar configures for f2.
I used the Siebert Optics Galaxy Viewer, a 6.3 focal reducer for binoviewers, in my Tele Vue Bino Vue. Also, I use the focal reducer setting in my Siebert 5 position Power Mag Wheel, as well as the focal reducer setting in my EarthWin system with no problem, but then I'm strictly visual. I used the EarthWin reducer setting with single eyepeices, also. I have not tried a conventional screw-into-the-visual-back FR.
#3 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 19 July 2010 - 08:19 AM
I have a 9.25" Edge HD and a Canon 450D. Celestron does not suggest using a DSLR for their Fastar scopes under 11" so I am probably out of luck there.
It's good to hear that you are able to use regular FR's for visual use with your Edge HD. There is hope.
#4 Starhawk
Starhawk
    Space Ranger
  • Loc: Tucson, Arizona
Posted 19 July 2010 - 09:08 AM
Talk to Starizona. Celestron doesn't make any optics to go on a fastar interface anymore.
-Rich
#5 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 19 July 2010 - 09:15 AM
Rich, I'm not looking for a Fastar setup. I was looking at an Optec reducer. It does not have a flattener built in so I was wondering if it would work with a 9.25" Edge HD. http://www.optcorp.c...5-172-173-10164
#6 Thomas A Davis
Thomas A Davis
Posted 19 July 2010 - 11:12 AM
I think the real issue is spacing. I tried the AP .75X
reducer (which does not have a built-in flattener), and
found that it had serious edge correction issues with my
9.25" EdgeHD. I used it as AP intended it, with their
SCT adapter. Celetron recommends 5.25" spacing between
the Schott flattener and the chip of a CCD or DSLR. How
that would translate to the use of a reducer with it, I'm
not sure. What I do know, and have posted proof of in
another thread, is that varying the spacing creates real
edge correction problems (it also changes the spherical
correction visually, much more that the same spacing change
would on a non-EdgeHD Celestron).
I've got a feeling that trying to use a focal reducer in
conjunction with a field flattener is creating fits for the
optical designers at Celestron, which is why we have not
seen one yet. At this point, anyone wanting to do SCT
imaging at anything other than F/2 (with HyperStar) or
native F/10 with the EdgeHD, would be better served using
a standard SCT with a reducer/corrector. It appears to be
more than just an issue of having a reducer that does no
field-flattening. In theory, a properly spaced reducer with
no field-flattening properties should work with the EdgeHD
flattener, but if that was all there was to it, I would
expect Celestron would have one available already. It may
be that a specially designed reducer may be needed (which
may even mean a specially designed unit for each size
EdgeHD SCT).
#7 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 19 July 2010 - 11:18 AM
Good points. I would have thought that a focal reducer with no correction of any kind would work if the astronomer was able to get the camera the proper distance from the back of the scope. I have read that Celestron will have different sizes of FR's when they come out.
I wish I could use my DSLR with the Hyperstar/9.25" HD but I have a feeling that I wont be able to.
#8 Thomas A Davis
Thomas A Davis
Posted 19 July 2010 - 02:44 PM
I wouldn't worry about using a DSLR with the 9.25". It
won't be too heavy for it, and the obstruction of the
camera will not pose an issue. I got this from Dean at
Starizona. It will work with Hyperstar and the DSLR when
it comes out for the 9.25" (none available now) later in
the year.
#9 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 19 July 2010 - 02:58 PM
That's good news. I wan't worried about weight really. I was under the impression that Celestron and Starizona did not suggest using a DSLR with Fastar/Hyperstar on a scope under 11".
#10 mclewis1
mclewis1
    Thread Killer
  • Loc: New Brunswick, Canada
Posted 19 July 2010 - 05:27 PM
That's because currently the only product under the C11 Hyperstar is the C8 Hyperstar, and DSLRs (even the small ones) are quite large compared to the C8 secondary.
Celestron has virtually nothing to do with the Hyperstar product, this is all Starizona's game. Celestron talks up the concept of fastar and makes scopes with fastar compatible secondonaries, that's about the extent of it.
#11 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 20 July 2010 - 04:00 PM
Makes sense. We'll see what Starizona comes up with for the 9.25". I'm not sure I want to spend that kind of money though. I would rather use a focal reducer in the back of the scope. It's tough imaging at f/10mm for me. I was hoping someone had tried out one of thier existing FR's and found it to work with the Edge HD.
#12 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 21 July 2010 - 11:47 AM
I am going to call Optic about this: http://www.optecinc....my/nguw_070.htm
#13 ewave
ewave
  • Loc: northwest NJ
Posted 21 July 2010 - 05:16 PM
Optec mostly for CCD chips no bigger than 18mm, too small for SLRs
#14 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 21 July 2010 - 06:38 PM
Actually, I talked to Jeff Dickerman at Optec and had a great conversation with him about this. They now make a FR specifically for the Celestron Edge HD and Meade ACF series.
They are f/6.2mm focal reducers in the Lepus Series:
"Lepus 0.62X Telecompressor Lens
New 4-element telecompressor for use with new well-corrected SCT designs including the Meade ACF and Celestron EdgeHD optical tube assemblies. With a longer back-focus over 100mm, the Lepus 0.62X is capable of fully illuminating a 22mm diagonal CCD. Can be used with any filter wheel/camera combinations with room to spare and can also be used with DSLR cameras. Optimal back focus distance is maintained by new Lepus line of camera mounts. Contact Optec for camera-specific mount."
They sell for $199.00 and need a specific camera mount that sells for $95.00. Part #19407. They are listed on Optec's price list but no information yet on the website.
Here are two pictures that he sent me.
The back end of an 11" Edge HD with the FR and camera mount:
A shot taken with that setup without flat fields:
Jeff is going to send me a processed image when the processing is complete.
This looks promising.
#15 ewave
ewave
  • Loc: northwest NJ
Posted 21 July 2010 - 07:04 PM
Hope so....it looks close to the recommended 5.25 inches from schott lens to camera sensor. Still for CPSC sized sensors, it is about a 27mm light cone.
#16 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 21 July 2010 - 08:03 PM
Jeff told me that it would be at 22mm for my DSLR but he also said that flats would be necessary based on the pics he has seen.
#17 Chris Rowland
Chris Rowland
Posted 22 July 2010 - 03:26 PM
What puzzles me about the Optec FR is how it can be OK for both the ACF and ED scopes.
AIUI the ACF is coma free but has a curved focal plane while the ED is both coma free and has a flat focal plane.
How can one FR correct for the curved focal plane in one case and the flat focal plane in the other?
Chris
#18 bradisback
bradisback
Posted 23 July 2010 - 04:10 AM
+1 Chris
#19 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 23 July 2010 - 07:11 AM
Good point. I may call Jeff back later today and get a clarification.
#20 bradisback
bradisback
Posted 23 July 2010 - 08:13 AM
It would be nice!!
#21 freemanpa
freemanpa
Posted 23 July 2010 - 10:22 AM
The pictures posted in message #3936128 are of my equipment (EdgeHD 11" and Canon 50D DSLR) and it's also my shot of NGC6992. I've had limited time out in non-foggy Ohio skies but I was happy with that shot. It was taken the same evening as when the picture of the setup was also taken.
The only reason the flat was not applied was simply that I forgot it until after I had switched to f/10 for a comparison shot. Jeff did ask me to apply a flat that I got through nearly-identical setup the following weekend, which I did, and it did a nice job of eliminating the lighter center. I am at work now or I would post that shot, if I can remember after getting home I will do so. Jeff does have that shot now also.
Overall, I have been quite happy with the image quality using Optec's FR. Next up is to try the same thing all over again using their TCF-Si focuser, which is being delivered today! :D
Here's hoping the Ohio skies cooperate over the next few weeks...
-- Pat Freeman
#22 Bowmoreman
Bowmoreman
    Clear enough skies
  • Loc: Bolton, MA
Posted 23 July 2010 - 10:57 AM
Hey Pat, welcome to CN and thanks for sharing your information with us.
Looking forward to having you as another active participant!
clear enough skies
#23 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 23 July 2010 - 02:17 PM
Thanks for chiming in Pat. When I chatted with Jeff at Optec, I was unclear if the focal reducer you used in those pictures was a production model or if you were testing it out for Optec. Either way, Jeff seems excited about your particular setup and it's results so far. I hope you don't mind me posting those pictures of your setup and your shot of NGC6992. They inspiring for those of us that hate imaging in f/10 and waiting for a focal reducer solution for the Edge HD's.
#24 Jeff Smith
Jeff Smith
  • Loc: Chicago
Posted 23 July 2010 - 02:19 PM
It looks like OPT is selling the Lepus FR now and they also claim that it works with the Edge HD series and the Meade ACF series. http://www.optcorp.c...5-172-173-15316
#25 Nocturnal
Nocturnal
  • Loc: CT, USA
Posted 23 July 2010 - 02:56 PM
Optec is here at MWAIC in Chicago so I'll ask them about this and report back.
