The Piston AZ mount
36 replies to this topic
#26 Gray
Gray
  • Loc: Tullahoma, TN
Posted 23 April 2011 - 09:04 AM
test
#27 Doug76
Doug76
    Long Achro Junkie
  • Loc: Refractor Heaven
Posted 23 April 2011 - 01:26 PM
As Eric and Frank opined...Awesome and Brilliant!
#28 Ed D
Ed D
  • Loc: Sunny South Florida
Posted 23 April 2011 - 05:55 PM
I'm VERY impressed! Nice work.
Ed D
#29 Tavi
Tavi
  • Loc: Romania, EU
Posted 28 April 2011 - 01:32 PM
Thank you!
Tuesday I've tried the mount with the refractor. The fine tune mechanism work great, except a small vibration on the azimuth. I will put a felt disk under the piston to brake it in position, cause the roler bearings allow moving it too easy.
I'm sure the mount will cary the future classic cassegrain 200 F/15 I will make this summer.
#30 Tavi
Tavi
  • Loc: Romania, EU
Posted 28 April 2011 - 01:35 PM
Neo, I will keep the idea of the worm gear for the next piston mount, I have a lot of them! Thank you and clear sky!
#31 Tavi
Tavi
  • Loc: Romania, EU
Posted 01 August 2012 - 04:40 PM
Because I had allmost finished the new clasical cassegrain 8" - wich I'll show you in another topic - and in the testing phase some problems has arised, I've made some improvements on the heavy piston AZ mount. First, I made a vixen style bar and adapt a vixen head from EQ6 mount, then a counterweight and the bar to put the telescope in equilibrium.
Cause the slips of the altitude clutch and the too big backlash of the fine tune mechanism on the azimuth, I've made some modifications to solve these problems.
Also I put new knobs on the screws and a eccentric lever instead a screw to activate the altitude clutch. To make the movements smoother I put custom lexan washers instead steel ones.
Now the mount work great, like when small refractors was on it, almost like a dobsonian when not used the fine tune mechanisms.
#32 Tavi
Tavi
  • Loc: Romania, EU
Posted 10 January 2013 - 03:18 PM
A new small piston AZ mount, finished last month:
#33 Tavi
Tavi
  • Loc: Romania, EU
Posted 10 January 2013 - 03:23 PM
The new mount has fine tuning screws on both axis and a vixen style head. The RFT refractor 90x600 in the picture is too heavy for it, but I use this mount with the mini maksutov MTO11-CA and is working great.
The only piece made on a lathe is the elastic textolit bushing which is the altitude clutch. Other pieces was made using hand tools and the homemade minimill.
#34 Unknownastron
Unknownastron
  • Loc: CatsEye Observatory,Rural Southern Oklahoma
Posted 25 January 2013 - 12:43 AM
Very good ideas and beautiful work. You are a very talented craftsman and your finished works look as much like art as machine. I look forward to your threads about that beautiful metal cassegrain. That is one of the best-looking telescopes I have ever seen.
Clear skies and clean glass,
#35 jmclaugh2001
jmclaugh2001
  • Loc: Midwest
Posted 25 January 2013 - 02:18 AM
Sweet! I luv it!!
John
#36 Tavi
Tavi
  • Loc: Romania, EU
Posted 25 January 2013 - 02:27 AM
Thank you!
I could't wait to bring them again under the dark sky.
#37 Tavi
Tavi
  • Loc: Romania, EU
Posted 25 January 2013 - 02:45 PM
unknowastron, here is the topic about the cassegrain with details:
http://www.cloudynig...&Board=atm&N...
