RS232 to USB Adapter
4 replies to this topic
#1 kohudson
kohudson
Posted 15 August 2010 - 08:04 PM
Hi Everyone,
I need an RS232 to USB adapter to connect a Takahashi EM-200 to a PC. Can anyone recommend a good converter and a good company to order it from? Preferably somebody with fast service!
#2 Avi
Avi
Posted 15 August 2010 - 08:08 PM
Got mine from Newegg.
http://www.newegg.co...&Tpk=12-186-105
Works great with XP. According to one review, not so much with Vista 64 Bit. YMMV
#3 CarolG
CarolG
Posted 15 August 2010 - 08:37 PM
I use the Keyspan (recommended by other CNers when I was looking for one). It has worked flawlessly on XP, VISTA, and Win 7 Pro 64 bit. It has its own drivers, which I understand helps the performance. This is the one I'm referring to.
#4 Wolf on Air
Wolf on Air
Posted 15 August 2010 - 09:26 PM
Basically anything using a chip from FTDI will work fine on nearly any OS (though you will have to download their drivers for Windows and MacOS). They have a webshop, here's their selection of pre-made USB-to-DE9/RS232 cables (I'd recommend the LED-free version!) though they have many other options for the DIYer, in various voltages, including wire-ended versions that you could attach any connector on. There's plenty of other options, of course, and for basic RX/TX/GND connectivity which is all that's needed for any sort of telescope mount I've seen, most things would work, though driver quality can be very variable.
#5 kohudson
kohudson
Posted 16 August 2010 - 10:21 AM
Thank you all - I ended up purchasing a Keyspan USA-19HS adapter from Amazon.
Thanks again,
