What Formica do I have here?
9 replies to this topic
#1 oddog
oddog
Posted 16 November 2010 - 07:25 PM
I picked a 30" x 66" sheet of black pebble finish Formica from telescope shop. On the back is stamped "00909 1242 HGP NSF35 123274 Made in USA EV FORMICA Line 5 100308 0550" (whew!). Is this the stuff from which DOB's are made? Thanks in advance. Tom Duncan
#2 GlennLeDrew
GlennLeDrew
Posted 16 November 2010 - 07:49 PM
Sounds to me like it could well be the so-called 'Ebony Star', the more so if obtained at a 'scope shop. The pebbled finish reduces stiction with teflon.
#3 TurbineTester
TurbineTester
Posted 16 November 2010 - 08:56 PM
Post a picture of the surface and anyone who has seen the ebony star should be able to tell you if it matches...
#4 dave brock
dave brock
Posted 17 November 2010 - 12:13 AM
Since Ebony Star is Wilsonart, it's not that. In New Zealand, all Formica sheets have the colour and finish printed on the back.
Dave
#5 dave brock
dave brock
Posted 17 November 2010 - 12:25 AM
Just Google searched 00909 1242 HGP NSF35 123274 Made in USA EV FORMICA Line 5 100308 0550 and the only result was this thread. :4
Dave
#6 sixela
sixela
Posted 17 November 2010 - 03:03 AM
what you're interested in is the finish. It's either a three letter abbreviation (like "QRY") or a two/three letter code (UN, 75, 075, etc. -- "75" is QRY). On mine, it's stamped "QRY", which at least with Formica is the finish you want.
It's strange, because that code is usually what you see on Wilsonart laminates (perhaps it's a US thing?), and those obviously never include "FORMICA" as that's a trademark from a competitor. In the Wilsonart codes, the finish immediately precedes the NSF-35 and you want -50 for the correct "Ebony Star" finish for scopes, but "HGP" is something much more generic and IIRC not a finish (it refers to the thickness - HGP is "postforming", usually 0.99mm nominal thickness for the high pressure laminate itself).
I'm stumped. Are you sure there are no other Formica-specific codes printed somewhere else?
#7 Mirzam
Mirzam
Posted 17 November 2010 - 06:01 PM
The only thing to be concerned about is the finish. Pebbly is good. Don't worry about the brand.
JimC
#8 oddog
oddog
Posted 18 November 2010 - 03:27 PM
There are no other codes on the sheet. Here is a close-up of the surface finish...
If this stuff is usable for telescope applications, what is it worth (this sheet is large, 30" x 66")? Is this stuff hens teeth or a carton of milk? Tom
#9 sixela
sixela
Posted 18 November 2010 - 03:51 PM
this is the Quarry finish we're using.
I'd guess your finish is fine too.
#10 Pinbout
Pinbout
Posted 18 November 2010 - 06:15 PM
the 909 is the color black
the 1242 is for:
12 is the grade [postforming] 42 is the finish - crystal
hgp is postforming grade - you can heat it to bend around a bullnose [why they repeat the grade spec?]
nsf35 is for food service
