Uranus Observation (November 16, 2010)
17 replies to this topic
#1 CarlosEH
CarlosEH
Posted 30 November 2010 - 01:52 AM
I made an observation of Uranus on November 16, 2010 (02:00 U.T.; CM 234.5*, De 9.1*, Ds 11.4*, 5.8m, 3.6") using my 9-inch (23-cm) F/13.5 Maksutov-Cassegrain (310x, S: 6-7/10, and T: 4/6). The preceding and following limbs (circumpolar and temperate latitudes) exhibited a brightening (7/10) whereas the equatorial region appeared dusky (4/10) and irregular. These features were more easily noted when the seeing steadied for moments at a time. The best of luck in your own observations of Uranus.
A digital image produced in Pixelmator.
Carlos
#2 george golitzin
george golitzin
Posted 30 November 2010 - 04:02 AM
Wow, a very nice observation. I have never seen detail on Uranus. Perhaps not thinking there was any to be seen, I haven't spent a lot of time observing it.
Thanks for the sketch, you've inspired me to take a closer look.
#3 CarlosEH
CarlosEH
Posted 30 November 2010 - 04:22 AM
George,
Thank you for the compliment on my Uranus observation. Uranus is not an easy object to observe. Faint albedo features (as I have recorded) are visible at times over it's pastel olive-green (or teal) disk. Adequate aperture (typically >6 inches (15 cm); although some observers have detected detail using apertures down to 4 inches (10 cm)), diffraction-limited optics, steady seeing (atmospheric) conditions, and patience on the part of the observer are all required for the detection of albedo features (if any are visible) over this far member of the Solar System. The best of luck in your own observations of Uranus.
Carlos
#4 Jef De Wit
Jef De Wit
Posted 30 November 2010 - 06:19 AM
It must be impressive to see detail on Uranus. Good work Carlos!
#5 Heidescoper
Heidescoper
Posted 30 November 2010 - 06:51 AM
Carlos,
great cinema!
So many and different contrasted details - wow! :bow:
CS
Christian
#6 niteskystargazer
Posted 30 November 2010 - 10:05 AM
Carlos,
Very nice sketch Uranus :waytogo:
#7 Mentor
Mentor
Posted 30 November 2010 - 10:47 AM
Beautiful. There is not much else out there that will ask you to use that colour in your sketching.
#8 frank5817
Posted 30 November 2010 - 11:30 AM
Carlos,
A most impressive capture of distant Uranus.
Even at 310x it would take much skill to capture the detail you have recorded.
Wonderful.
Frank :)
#9 proud uncle
proud uncle
Posted 30 November 2010 - 01:25 PM
Great sketch, Carlos! I agree with others -- more detail than I've ever seen on Uranus. I just had a couple questions.
Did you initially do a rough sketch using pencil, then scanned it and digitally added color and detail?
Are the preceding and following limbs the polar regions, with the darkened band running from top to bottom being the equatorial region?
Thanks again for sharing!
#10 astronz59
astronz59
Posted 30 November 2010 - 02:25 PM
Outstanding, Carlos! Your observation and artistic abilities never cease to impress! :goodjob:
#11 rolandlinda3
rolandlinda3
Posted 30 November 2010 - 03:08 PM
Carlos, excellent observation and sketch.
#12 hbanich
hbanich
Posted 30 November 2010 - 04:31 PM
Holy smokes - that's more detail than I often see on Mars! Nice sketch as always Carlos, and I suspect your eyesight is a little sharper than most too.
#13 ericj
ericj
Posted 30 November 2010 - 05:10 PM
Wonderful sketch and report Carlos. You saw a lot of fine detail.
Best,
Eric
#14 CarlosEH
CarlosEH
Posted 02 December 2010 - 02:18 AM
Thank you all very much for the very kind compliments on my Uranus observation and planetary observing/sketching skills. I was fortunate to have been able to see such detail over this far pastel green member of the solar system.
I made my Uranus observation directly unto a template that I made in my computer. It is acceptable to scan a pencil (graphite) sketch and then add color and detail as noted in the eyepiece.
The bright regions are close to the poles of the planet and the dark band is roughly parallel to the equator. I have provided a modified screen shot of Uranus as produced by WinJUPOS 8.3 ( http://grischa-hahn....jupos/index.htm ). The north pole of Uranus is physically below the orbital plane of the planet (axial tilt of 97.8*). I hope that it helps.
Carlos
#15 mike174
mike174
Posted 03 December 2010 - 10:43 PM
Carlos,
How long did you observe before you detected those features?
#16 CarlosEH
CarlosEH
Posted 04 December 2010 - 03:14 AM
Mike,
I noted the albedo features over Uranus over the initial fifteen to twenty minutes of observing then continued to observe it for another thirty minutes waiting for moments of steady seeing to confirm them. As I pointed out previously, albedo features over Uranus are not always visible. The best of luck in your own observations of Uranus.
Carlos
#17 dweller25
dweller25
Posted 04 December 2010 - 11:39 AM
Carlos, I had a look at Uranus at opposition in my 5" refractor at x240 - it was tiny, so I know how much skill it takes to see those albedo features, very well done.
#18 CarlosEH
CarlosEH
Posted 04 December 2010 - 05:35 PM
Dweller,
Thank you for the compliment on my Uranus observation. Your Jupiter observations were excellent showing the SEB Revival (Disturbance). The best of luck in your future observations.
Carlos
