EQ7 is dead, Long Live EQ-8?
61 replies to this topic
#1 skybsd
skybsd
Posted 22 December 2010 - 03:12 PM
Aussie Astro community buzz suggests that the recently showcased Skywatcher-EQ-7 has been terminated in favour of another mount.
Synta's AP distributor (Tasco) apparently released the following announcement:
"Skywatcher announces that production of the EQ7 has been terminated and a new EQ8 is in design"
Merry X'Mas all :)
skybsd
#2 nemo129
nemo129
Posted 22 December 2010 - 03:31 PM
Well, that didn't last long. I love the speculation that the reason was '7' being an unlucky number in Chinese Culture. Some building in the west have no 13th floor!:crazy:
Merry Xmas to you skybsd!
#3 skybsd
skybsd
Posted 22 December 2010 - 03:45 PM
Hi Kirk,
Fun, isn't it :)
Many happy returns!!!
skybsd
#4 MaciekA
MaciekA
Posted 22 December 2010 - 04:24 PM
You'd be surprised how seriously that is taken, even in the west. Where I live there are dozens of buildings (including mine) no 13th floor (for the westerners), and there are no floors ending in 4 (in respect of Chinese culture, since there are many Chinese people in this area).
I haven't heard of 7 being their unlucky number, and 4 is definitely out, but I'd personally never underestimate the importance of those types of things in marketing across various continents/cultures.
#5 adamsp123
adamsp123
Posted 22 December 2010 - 04:26 PM
8 is lucky in China, so maybe it is the same mount renamed.
and number 4 is definately out!
#6 nemo129
nemo129
Posted 22 December 2010 - 04:46 PM
Maybe unlucky is too strong of a word. From the thread I read, it seems to be associated with spirits and ghosts in eastern cultures.
You are correct about the marketing aspect, numbers are free and if one has connotative association, it is just prudent to move along to one without issues, and apparently 8 is supposed to be a lucky number for the Chinese(thank you adamsp123). If it is more respectful to avoid certain things without causing undue issues...why not? The world could use more respect! Cheers!
#7 skybsd
skybsd
Posted 06 February 2011 - 06:35 PM
Some photos of the Skywatcher EQ8 at the start of this thread at another site.
#8 orlyandico
orlyandico
Posted 06 February 2011 - 09:06 PM
8 = money to the Chinese.
but they don't consider 13 to be unlucky, so most/all buildings i've been to have a 13th floor. dunno about the US (never been there) but in my home country of Philippines which used to be a US colony, 13 is unlucky and I've never seen a building with a 13th floor.
#9 pennyandchris
pennyandchris
Posted 07 February 2011 - 07:31 AM
Strange, cos' the Skywatcher importer was exhibiting the EQ8 at UK Astrofest over the weekend.
Very substantial looking mount. Way beyond what I want/need.
#10 neveruseforever
neveruseforever
Posted 07 February 2011 - 02:48 PM
I have seen Synta said the new mount was never named as EQ7. Nor EQ8 probably. Because there are already some cheap mount (by other Chinese companies) named EQ7 & EQ8.
#11 Twilight
Twilight
Posted 08 February 2011 - 03:18 AM
How do you get to the 14 floor if there is no 13th? Serious question.
#12 bardo
bardo
Posted 08 February 2011 - 04:38 AM
by elevator.
#13 rmollise
Posted 08 February 2011 - 06:16 AM
You hit the "up" button. ;)
#14 borix
borix
Posted 09 February 2011 - 03:47 AM
Why do they still use this bad power connector? :confused:
All other connectors seem to be much more secure.
#15 rmollise
Posted 09 February 2011 - 05:58 AM
"Seem." I've never had any trouble with the power connector on my EQ6.
#16 Planemo
Planemo
Posted 09 February 2011 - 09:09 AM
The power connector on my Atlas did "seem" to not hold in very securely so I just wrap the wire a few times around the very secure HC connection and then plug it in, this way the connector won't get a load that may pull it out. I would have designed some kind of clamp or screw on plug-in had I been in charge.
#17 lightyear44
lightyear44
Posted 09 February 2011 - 09:56 AM
Agreed, borix. When I had my Atlas, I had a terrible time with the power shorting-out. Whenever there was any movement of the power cable, it would shutdown for a split second, and I'd have to re-do the star allignment. A little piece of duct-tape at the beginning of each session eventually solved the problem, but that was just a band-aid. The connection for the hand-controller, was executed much better in the engineering dept. -David.
#18 lightyear44
lightyear44
Posted 09 February 2011 - 09:57 AM
....In fact, I knew another fella with the same problem. -David.
#19 alpal
alpal
Posted 10 February 2011 - 05:33 AM
Has anyone got some photos or some specs of this EQ8?
The best photo would be a side by side comparison
with the EQ6.
The EQ6 can't handle anywhere near it's rated capacity when doing photography.
An EQ8 might be the solution for a lot of people with
big Newts on Dob mounts to just put them straight on
a large mount & start taking 10 minute sub frame photos.
WOW
#20 hapo
hapo
Posted 10 February 2011 - 08:25 AM
The differences between EQ7/8 and EQ6 are like between CGE PRO and the CGEM. While CGEM is a redesign of EQ6, the Eq7/8 is a redesign of the CGE PRO. EQ7/8 is very much like the CGE PRO, in dimensions and desing, except a few differences from motors and software, and cosmetic.
#21 Planemo
Planemo
Posted 10 February 2011 - 09:30 AM
with the EQ6.
Scroll down this page web page and there is a very good pic of it, but not side by side to the EQ-6, doesn't look like something I'd want to tote around, better suited for a permanent pier.
#22 alpal
alpal
Posted 10 February 2011 - 10:12 AM
with the EQ6.
I scrolled down that page & the the next page but I didn't see it.
#23 skybsd
skybsd
Posted 10 February 2011 - 10:28 AM
with the EQ6.
Its there.., here you go.
skybsd
#24 Kenny2004
Kenny2004
    Vendor - Icodome
Posted 10 February 2011 - 10:44 AM
It looks huge! So when is the North American release date on this monster?
#25 skybsd
skybsd
Posted 10 February 2011 - 12:19 PM
No idea as to a N American launch to me knowledge.
Rumours in AP suggest that they will be the first geography to see it..,
skybsd
