Vibration pads
11 replies to this topic
#1 Dewdney
Dewdney
Posted 22 January 2011 - 06:09 PM
Picked up a heq5 pro and it will be my mount for a TEC 140. Are a set of vibration pads of any value to help dampen or would you have other suggestions. This was the best mount ( at least for me) I could get with the resources I had avaiable but realize it will have limitations that will eventually require an upgrade but so goes life. This is for visual only. I desired the scope more then a top line mount at this time
Thank you for your advice in advance
Thank you
#2 Asimov
Asimov
Posted 22 January 2011 - 08:16 PM
They worked 110% for my situation, but my situation was unique - I have the problem of 'drumming sand' Our whole township is built on sand very close to the ocean, & every time a car drives past our house on the closest road (which is at least 120 ft from the house) I could see the vibes created through the EP. As for imaging, it totally destroyed any images. The pads killed the problem stone cold dead. :bow:
#3 Dewdney
Dewdney
Posted 22 January 2011 - 08:57 PM
Thank you. Wish I had your weather about now
#4 Asimov
Asimov
Posted 22 January 2011 - 09:00 PM
No you don't lol - I haven't had a clear night in over 3 months, due to me being in the tropics in Australia :help:
#5 Dewdney
Dewdney
Posted 22 January 2011 - 10:07 PM
Well I could send you the 2 metres high of snow on my front or back lawn. Even when nice weather sort of hard setting up the rig
#6 Eddgie
Eddgie
Posted 22 January 2011 - 10:08 PM
I use them on all my mounts. Even the CGE. OF course the big mounts squish the sorbathane out, but they sure do help reduce vibration!
Highly recommended.
#7 Dewdney
Dewdney
Posted 22 January 2011 - 10:10 PM
Thanks will pick some up really won't add much cost to the overall set up ha ha
#8 Asimov
Asimov
Posted 22 January 2011 - 10:14 PM
Highly recommended.
Well, I have imaged in snow when I lived in the States for a period (VA) but not 2M of the stuff! :shocked:
You can keep it :lol:
EDIT: Woops! I quoted the wrong post :foreheadslap: However I'm sure you guys will work it out :p
#9 David Pavlich
David Pavlich
    Transmographied
Posted 22 January 2011 - 10:28 PM
Highly recommended.
:lol: Boy, do I know what you're talking about. I set my first CGE/C11 on a set and yikes! Did not do them well. :ohgeeze: However, they are terrific for an Atlas and below. They do work as advertised.
David
#10 Asimov
Asimov
Posted 22 January 2011 - 10:31 PM
It's a pity they don't make vibration pads with varying densities of sorbathane, with varying weights of different setups in mind..
#11 Phil Wheeler
Phil Wheeler
Posted 23 January 2011 - 05:11 PM
Definitely worth using. I have two sets of Celestron vibration pads and really see the difference visually when using them.
#12 russell23
russell23
Posted 23 January 2011 - 05:27 PM
Dittos to what everyone has said. I use a pair of celestron antivibration pads and they work extremely well. I can definitely see the difference when I use them vs. when I don't use them.
Dave
