Fixed annoying Dec control issue on CG5
5 replies to this topic
#1 Rossmon
Rossmon
Posted 31 January 2011 - 08:39 PM
Imagine spending time to push your scope onto or close to a DSO and intermittently when you press a Dec button on say a rate of 4 it flys off the handle at top speed! This has been happening, on and off for the last couple of months. I finally tracked it down to the cable between the 2 Dec ports. Wiggling the end where it plugs into the Dec motor caused it to work at either full speed or the set rate. Don't know which pin was the problem but reversing the cable fixed it until I buy or build a replacement.
#2 BlueGrass
BlueGrass
Posted 31 January 2011 - 09:53 PM
Ross,
Many folks invest in an RJ crimping tool. Sometimes, just recrimping the plugs fixes many cable problems. If that doesn't work, you can buy a small bag of replacement plugs and crimp a new one on the existing cable. Much cheaper than a new cable.
#3 Mike X.
Mike X.
Posted 01 February 2011 - 01:37 AM
Yep i agree with George, same thing i did,best 6 euros spent on an accessory.A crimping tool ;)
#4 rdandrea
rdandrea
Posted 01 February 2011 - 10:46 AM
Me too. Totally fixed my 16 and 17 errors.
#5 Rossmon
Rossmon
Posted 01 February 2011 - 08:13 PM
Thanks I think I own the tool already! Will give it a try.
#6 Rossmon
Rossmon
Posted 04 February 2011 - 07:34 PM
Well now I'm really in deep. After crimping my new cable and attaching in the darkness, I plugged things in backwards. Dec to HC PORT ETC and blew motor control board. Oops. :-(
