Portable Mount
5 replies to this topic
#1 gcuff
gcuff
Posted 02 February 2011 - 10:43 AM
I am looking for a portable GOTO mount (head max 25lb) that can be used as a grab and go but also for AP with up to a 11lb APO. I looked at the CG-5GT but as I live at 20 degrees North there are issues with the latitude adjustment. The Ioptron 45 is a possibility but I am concerned about its "newness". I have a possibility of a lightly used well priced Vixen SXD but wonder whether a Sirius EQ-G would give me similar performance at a much lower price point. And then there is the GM-8.
Your comments and experiences would be very much appreciated
Geoff
#2 Ad Astra
Ad Astra
Posted 02 February 2011 - 02:24 PM
There was a nice review thread about the new iOptron mount on CN mount forum just a while ago. You can search there and get lots of good info.
DB
#3 gcuff
gcuff
Posted 02 February 2011 - 03:02 PM
Thank you for your reply.
Yes I read that (all 34 pages) and certainly meets a lot of the criteria but there were some quality issues. The other mounts I have no experience of and, living outside of the USA, it is not easy to "touch and feel" mounts in a local store.
I suppose an Mach 1 would solve everything, including emptying my wallet:)
Regards
#4 doctordub
doctordub
Posted 02 February 2011 - 04:05 PM
You could use a Vixen SXW for the weight you will be imaging with. The price for new and used SXW is much lower than the SXD.
CS
#5 phil piburn
phil piburn
Posted 02 February 2011 - 05:26 PM
What about the new Clestron LCM go to mount. Been wanting
one myself but have not read anything about them.
#6 Lane
Lane
Posted 02 February 2011 - 05:52 PM
Cannot comment on the other mounts but the Sirius is a nice light little mount that is very quiet when doing goto's. I really like it a lot, but it does not handle weight well. With 25lbs on board you are going to have vibration issues even with vibration pads under the legs. I use mine only for visual observing with my C8 or my AT106, which are both 13.5lbs counting the mounting hardware. Tried it with a C9.25 and the level of vibration was to annoying even for visual use, and that was only 24lbs.
