Is the LXD-75...
30 replies to this topic
#1 Don Allen
Don Allen
Posted 06 February 2011 - 08:13 PM
when compared to Orion mounts, in carrying capacity, equal to the Skyview Pro or the Sirius:question:.
#2 hfjacinto
hfjacinto
    I think he's got it!
Posted 06 February 2011 - 08:16 PM
I have had a 9.25 on my LXD 75. Its fine visually but its much better with the 120MM EON.
#3 Don Allen
Don Allen
Posted 06 February 2011 - 08:55 PM
I want to put my F15 on the Sirius if it works instead of buying the heavy, for my aging muscles, Atlas.
#4 hfjacinto
hfjacinto
Posted 06 February 2011 - 09:15 PM
This is the EON on the LXD 75, an F15 scope, may be too long.
#5 Don Allen
Don Allen
Posted 06 February 2011 - 09:41 PM
I will say this, my lxd 75 was 84% capable of handling the F15, but it was a struggle.For me and the mount.
#6 AlienRatDog
AlienRatDog
Posted 06 February 2011 - 09:50 PM
How does the EON120 ride on that? Pretty stable?
#7 hfjacinto
hfjacinto
Posted 06 February 2011 - 10:20 PM
Abe,
LXD75 handles the EON fine. The EON is light.
#8 gustavo_sanchez
gustavo_sanchez
Posted 07 February 2011 - 01:55 PM
I think that the LXD-75 is more comparable overall to the CG-5 ASGT. The Sirius has a similar loading capacity, but mechanically is more sturdy, and, on my opinion, better built.
#9 gdd
gdd
Posted 07 February 2011 - 02:20 PM
I believe the LXD-75 is supposed to be similar to both the CG-5 and the Orion SkyView Pro. All of these are clones of the Vixen GP.
Gale
#10 Don Allen
Don Allen
Posted 07 February 2011 - 04:31 PM
I am reading from these comments that the sirius would have more capacity then the LXD75 by a reasonable
percentage. Say 20-30%.
#11 hfjacinto
hfjacinto
Posted 07 February 2011 - 04:47 PM
I would agree with your statement.
#12 DaveE
DaveE
Posted 07 February 2011 - 04:50 PM
The Atlas is considered a "Step up" from the EQ-G by Orion (and $250 more), yet would you classify the Atlas and LXD75 as competitors and similar in capability? But the EQ-G has more weight capacity?
-Dave
#13 DaveE
DaveE
Posted 07 February 2011 - 04:53 PM
Actually, the EQ-G has a 30lb max load while the Atlas has a 40lb max load.
One day when I purchase only one mount, I always thought of myself as getting either an Atlas or CGEM to mount the EON 120 with an 80mm piggyback. I never thought to get the less expensive Sirius EQ-G... and yet Orion sells this exact combination as a kit:
http://www.telescope...actor-telescope
I'm wondering if this combination would handle the added weight of a piggybacked guidescope?
-Dave
#14 bardo
bardo
Posted 07 February 2011 - 05:32 PM
-Dave
:roflmao:
...NO
#15 Don Allen
Don Allen
Posted 07 February 2011 - 07:19 PM
Well thanks all. I wanted to avoid getting the Atlas or the G-8 as this is the only refractor I am going to own so the Sirius is it.
#16 avarakin
avarakin
Posted 07 February 2011 - 08:11 PM
In my opinion, LXD should be better than CG5 because:
1.LXD75 has ball bearings on both RA and DEC, CG5 only on RA
2.LXD75 has reduced slew rate mode which is good for long tubes
I was able to run my 10" F5 #40 reflector on top of it for visual only. After balancing it was running very smoothly.
The only problems I had were:
1. EP too high so I had to stand
2. Goto errors of about 3degree in the worst case
Otherwise tracking and motors were running just fine.
At $475 shipped from Meade outlet, it is a killer deal.
Alex
#17 DaveE
DaveE
Posted 08 February 2011 - 04:11 PM
-Dave
:roflmao:
...NO
I meant to ask if you believe the Sirius EQ-G and LXD75 are competitors and similar in capability?
-Dave
#18 Don Allen
Don Allen
Posted 08 February 2011 - 07:25 PM
Considering the Sirius costs $350-400 more than the LXD, even on the used market, I would hope it has more capacity.
#19 avarakin
avarakin
Posted 08 February 2011 - 08:05 PM
Well, Sirius costs about twice the LXD75 costs (1150 vs 600). Do you get twice performance? I dont think so.
#20 rmollise
Posted 09 February 2011 - 06:02 AM
Alex
Three degrees doesn't constitute "better" in my book. My CG5 has placed objects on the small chip of my Stellacam since day one.
#21 orlyandico
orlyandico
Posted 09 February 2011 - 08:45 AM
I think the goto errors on the LXD75 are due to the *BLEEP*-poor encoder wheels on the motors.
This is why Deep Space Products sells upgraded encoder wheels for the LXD75. :-)
#22 rmollise
Posted 09 February 2011 - 08:56 AM
I know they are thin, flimsy, easily damaged and separate from the motors.
I do think the LXD 75 is somewhat better than it used to be, but the last star party I was at a couple of dudes had stripped their 75 down to parade rest to try to deal with slipping transfer gears. :bawling:
#23 Don Allen
Don Allen
Posted 09 February 2011 - 11:52 AM
Uncle Rod,
The gears were the issue with my LXD75. No matter how I adjusted them they would continue to slip.
#24 jgraham
jgraham
Posted 09 February 2011 - 12:34 PM
Hmmm, 6 years and 2 LXD75's later mine have always given excellent service. Accurate GoTo's require good calibration and drive training, most of the problems I've seen were due to skipping the calibration step. A good power source is a big help as well. The few cases of gears slipping that I've seen were easily fixed with a spot of Locktite on the set screws. At least that has been my experience.
#25 DaveE
DaveE
Posted 09 February 2011 - 01:12 PM
All I want is a portable mount that's goto/tracking PLUS easy enough for grab-n-go without power... take it out back, mount the scope, point and enjoy without power, aligning, or the controller, just like my Vixen porta. Only if I want goto/tracking will I bring the battery out and align it.
But this mount needs to be able to hold anything from a little 6lb 80mm refractor to a big 15lb 5" job with a piggybacked guide scope. The reason is I don't really want to spend twice on two mounts.
But what I'm finding out is you can't have it all... I need to buy a good manual alt-az for grab-n-go like my Vixen porta but one that can handle 15lbs... but then I also need to just bite the bullet and buy an Atlas too.
-Dave
