Remote control of my vixen mount solved!
7 replies to this topic
#1 vpcirc
vpcirc
Posted 10 February 2011 - 11:37 AM
I finally figured out to run my vixen mount from in the comfort of my office. After entering scope mode, I connect the crossover LAN cable to my laptop (which I need to run phd and nebulosity) I then start the sky 6 and link to the mount. I can then run everything from the sky except initial alignment. I can slew to alignment stars with the sky, but I still must center and align on the starbook. I then start windows desktop remote control on my desktop, (you need windows 7 professional installed on the laptop) and for the rest of the evening I can sit inside for the entire evening. The only quirk I've found is when linking the vixen to to the sky 6, I have to choose setup each time in the telescope panel, then it will establish a link, and I'm good to go.
#2 charles1317
charles1317
    I See Stars
Posted 10 February 2011 - 07:49 PM
You connect the crossover cable between the laptop and the PC inside?
#3 orlyandico
orlyandico
Posted 11 February 2011 - 12:20 AM
what other folks have done is connect the Vixen to a wireless access point's LAN port. the AP has to be configured on the same LAN IP address segment as the Vixen (which I assume is a Starbook -- it has a hard-coded IP address).
so your laptop can be indoors (allow it to connect wirelessly to the AP).
#4 vpcirc
vpcirc
Posted 11 February 2011 - 05:28 AM
I connect the crossover LAN to the laptop and run the laptop indoors via windows remote desktop. I still need the laptop outdoors to plug the ccd camera and auto guider into. It just let's me sit inside to do everything once the system is aligned. Guess if I had a self guiding camera and a ccd that could remotely save images..., but most of us dont. Guys move the scope with ski safari already, but my goal is AP, which ski safari is
pointless unless I want to stand outside observing, and I was too lazy to pick up the starbook.
#5 nemo129
nemo129
Posted 11 February 2011 - 09:23 AM
Hey that sounds great that you got that figured out. So overall are you happy with the SXD? Not to be off topic, but I keep seeing them pop up on that other site and have been tempted to grab one.
#6 vpcirc
vpcirc
Posted 12 February 2011 - 08:09 AM
After owning a CGEM, I would take a Vixen hands down. Once you understand how to set it up correctly it's a dream. The polar scope is the most accurate one out there (no more drift aligns) Once I align the first star, every subsequent star appears in an orion 12mm crosshair ep. Half the time the CGEM would be off by 5 deg. I guide consistently for 15 min exposures for hours at a time with a loss of 20-25% of the frames. AP used to be a nightmare for me, now it's a dream.
#7 orlyandico
orlyandico
Posted 12 February 2011 - 08:58 AM
vpcirc, am interested in your SXD experience.
there have been persistent reports of excessive DEC backlash that makes guiding very difficult. have you experienced this and can you elaborate?
#8 vpcirc
vpcirc
Posted 12 February 2011 - 12:24 PM
There was dec issue with stiffness and a little noise that was an issue, but they released a motor firmware upgrade last year that ended that problem. The dec can be a little stiff for balancing, but it's not difficult to adjust see here;
http://enzerink.net/...n-star-book-faq
but I am able to balance with ease, maybe because I'm using a side by side configuration?
