Replacement legs for LXD55
3 replies to this topic
#1 Loki1972
Loki1972
Posted 10 February 2011 - 10:12 PM
Anyone know a source for 1.75" or 2" steel tube legs that will work on a LXD55 mount?
Would really like to replace the extruded aluminum legs it came with.
I know of GTO's wood legs, and will go with them if there's no other option, but would prefer steel tube legs.
#2 Eddgie
Eddgie
Posted 10 February 2011 - 11:48 PM
The legs off of the newer CG5 or LXD-75 I don't think will work. The hub design is a bit different (not positive on the LXD-75, but I THINK it is different thant the LXD-55 attachment too).
So, you would need a complete tripod including the spreader and the hub at the top.
I don't think you can replace ONLY the legs in this case. Just need to find a complete tripod.
#3 bardo
bardo
Posted 11 February 2011 - 02:46 AM
clearview optics sells whole steel tube tripods.
#4 K_van
K_van
Posted 12 February 2011 - 01:04 PM
Hi dont know if this helps but I have the ST3A tripod with my eq5 mount and find it quite stable. Another alternative might be a wood surveyors tripod but would require some work to adapt it. There are several good threads here regarding this. I just picked up the Secco 5220-10-ORG at
chief supply but have not yet mounted my cg-4 to it. The price seemed quite reasonable and all fitting appear to be steel not plastic.
http://www.chiefsupp...eco/5220-10-ORG
