Atlas/Sirius Counterweight compatible with CG5?
10 replies to this topic
#1 rmallen
rmallen
Posted 13 February 2011 - 10:38 AM
Does anyone know if the Orion Atlas/Sirius 11 lb counterweight (#09863) will fit on the CG5? I need another counterweight for my CG5 mount and the Orion counterweight is on sale right now.
#2 orlyandico
orlyandico
Posted 13 February 2011 - 10:59 AM
No. The Atlas uses an 18mm C/W shaft while the CG-5/Vixen GP uses a 20mm shaft.
I am using 2 Atlas weights on my Vixen but I had to have someone bore them out with a big honking drill bit.
#3 rmallen
rmallen
Posted 13 February 2011 - 11:05 AM
OK, thanks. Guess I will have to go with the Celestron CG5 weight.
#4 ad701xx
ad701xx
Posted 13 February 2011 - 11:49 AM
The Orion Skyview Pro counterweights (#07384) are on sale also and fit the CG5. Why not order those?
#5 rmallen
rmallen
Posted 13 February 2011 - 12:17 PM
Thanks Dave. Unfortunately, it looks like the Skyview Pro counterweights are only 7.5lb and I need a little more weight than that.
#6 ad701xx
ad701xx
Posted 13 February 2011 - 12:30 PM
Sorry, I read your post too fast and missed the 11 lbs part.
#7 Jeff in Austin
Jeff in Austin
Posted 13 February 2011 - 02:48 PM
I'm using the Atlas and CG5 counterweights on my Atlas. One of them has a plastic sleeve, I think thats the Atlas one. The sleeve pops out easily.
Here are some diameters I measured today: CG5 shaft is .780, Atlas is .710. CG5 weights have a .815 opening, Atlas has .800 if the sleeve is popped out, .715 with the sleeve.
#8 vinnie
vinnie
    Minister of Misinformation . . . Oh Yes
Posted 13 February 2011 - 05:28 PM
That's correct Jeff
All Synta CWs are bored to suit the 20mm shaft which is the shaft size for CG5/EQ5/EQ3. Those sold to suit the 18mm shaft as fitted to EQ6/HEQ5 (Atlas/Sirius) simply have a plastic sleeve fitted which is easily removed.
#9 rmallen
rmallen
Posted 13 February 2011 - 07:43 PM
Thanks guys. I ended up ordering the CG5 counterweight. I found one at a reasonable price with free shipping. It was only $1.64 more than the price for the Orion weight after figuring in the shipping.
#10 RandallK
RandallK
Posted 15 February 2011 - 01:22 PM
I always put my finger inside the counterweight hole when when I loosen the knob to dismount or mount it so that sleeve doesn't come out. I think all the Synta weights have the same potential problem.
#11 Mary B
Mary B
Posted 15 February 2011 - 05:27 PM
It fits with the plastic spacer out. Just put one on my CG5.
